Rich
 K3 Anti-roll bars
My car currently lacks bars at both ends, what options are open to K3 owners? Am I right in thinking that K series Metro bars originally mounted to the vehicle bodywork?
| Sun May 01, 2016 10:52 pm |
catsam
 Re: K3 Anti-roll bars
Hi rich I have anti-roll bars on my one I don't know how they fit to the metro but I can take some photos of my own so you can see how they fit it looks simple a couple of rod ends
Regards Paul
| Wed May 04, 2016 9:59 am |
Rich
Yes please!
| Fri May 06, 2016 9:46 am |
catsam
| Fri May 06, 2016 4:58 pm |
Rich
Thanks Paul, are those original metro bars or custom made? I note the links going up rather than down. I don't suppose you have a pattern for those damper mounts do you?
Rich
| Sat May 07, 2016 3:10 am |
catsam
sorry i do not have a pattern for those damper mounts they was on the car when i got it (look like some angle iron just bent ) i think they are original metro bars but i think the link is custom made?
| Sat May 07, 2016 4:31 pm |
Rich
catsam wrote: sorry i do not have a pattern for those damper mounts they was on the car when i got it (look like some angle iron just bent ) i think they are original metro bars but i think the link is custom made? Yes it looks that way, thank you for posting those up. There's a bit of uneasiness in the handling, nothing alarming, but it does remind me of vehicles I've run in the past without bars fitted for trialling.
| Wed May 11, 2016 11:18 am |
jaybee
Joined: Sun Oct 15, 2017 7:44 am Posts: 139 Location: Glasgow GTM: Rossa
Rich. Unless your car was built using a Metro GTi subframe, then there will be no roll bars. The easiest way to do it is to fit the MGF front set up, but this will involve welding brackets for the front mounts to the subframe and a pair to the bottom suspension arms as they are not present on the standard Metro set up, OR just fit a full MGF front and rear end   J.
| Tue Jun 05, 2018 3:57 pm |
Spanners and CDS tube is the answer!
| Wed Jun 06, 2018 8:37 am |
