K3 handbrake cable, standard Metro or special?
Post K3 handbrake cable, standard Metro or special?
As the ongoing rebuild of the tail end of my K3 progresses I'm left looking at a rather tatty and hacked about handbrake cable. It isn't clear if I'm looking at modifications or repairs here. Is the cable a standard Metro/100 cable or was it a special for the K3?
If it makes any difference I have the rather bizarre looking 2CV handbrake calipers fitted.
Thanks,
Rich
Sun Nov 23, 2014 12:27 pm
Post Re: K3 handbrake cable, standard Metro or special?
Hi Rich
I've looked thro' all the K3 info I have and can find no reference to handbrake cable.
I assume therefore that it must be from the donor Metro.
The GTM K3 caliper assembly was not very good so I've been told.
I think the MGF one is the recommended modification.
Maybe a K3 owner will reply with advice.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Sun Nov 23, 2014 5:34 pm
Hi Alan,
Thank you for having a look, much appreciated. The 2CV option on mine is never going to be high performance but it seems to do the trick and now I've stripped and cleaned them down they should be a little better. Would I be right in thinking that fitting the MGF option would mean using the F uprights and a new set of wheels to clear them? I'm currently using the 13" GTi wheels from the original donor.
Sun Nov 23, 2014 5:41 pm
Hi Rich
Although I now have the original GTM K3 info and
some of the moulds I have no experience of working
on these Rossas.
Hopefully a helpful K3 owner will reply.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Sun Nov 23, 2014 6:09 pm
No worries, many thanks for taking the time to reply Alan.
Sun Nov 23, 2014 6:28 pm
Hi Rich,
the MGF upright is a bulky affair and is attached by a track control arm and a trailing arm with an adjustable tie rod for toe adjustment and as such will not allow a 13 inch wheel over it. I have mgf rear with 14 inch compomotives and i had to grind a little bit of relief otherwise one connection wiped off the stick on balance weights as its that close. MGF wheels are 15 inch alloys with a 14 inch steel spare.
The mounting holes for the MGF rear caliper are 85mm centres so look at your existing hubs to see whether you could adapt to fit.
Hope this helps,
Peter.
Sun Nov 23, 2014 9:58 pm
I believe that a standard handbrake cable is used but mine was shortened using u clamps after it had been bent back on its self not idea but seemed to work.
Matty
Sun Nov 23, 2014 10:00 pm
Thanks gents,
I've ordered a standard handbrake cable as a quick search of eBay shows they are silly cheap, I may well have to look at options for shortening it. There's no plans to convert to an MGF rear just yet, the metro brakes are more than adequate for the way I drive. If I go to a bigger engine I may have to revise that.
Rich
Mon Nov 24, 2014 10:30 am
hi I have found this in the workshop manual
I have scanned the pages and it does say that it utilises the standard k series metro handbrake
hope this can help
[url]Image[/url]
[url]Image[/url]
[url]Image[/url]
Wed Nov 26, 2014 12:27 pm
That is how mine was.
Matty
Wed Nov 26, 2014 7:43 pm
Ha! That's what my 'hacked about' cable looks like with the cable repair U bolts on the nearside and main pull. I might see if I can get one modified. Thank you for the scan of the manual, any idea where I could pick up a copy? It's always useful to see what the kit maker was getting at when you are trying to work out what is going on with something.
Wed Nov 26, 2014 9:53 pm
Hi Rich, I'm pretty sure Alan (Rosabitz) has these in stock
Thu Nov 27, 2014 1:05 am
