It is currently Sun Jun 21, 2026 11:57 am
brake set-up advice
Post brake set-up advice
Hi All,
Please advice about the right brake set-up for my coupe.
My try and error method failed. At the rear I fitted solid disc.24 mm.and MG calipers with one piston 35 mm..
Which disc, caliper,pedalbox and mastercilinder will give the best results.
I look forward to your advice
Wim from Holland
Wed Sep 22, 2010 1:26 pm
Post Re: brake set-up advice
That totally depends on what you want to do with the Coupe, I had uprated 1275 GT mini brakes on the front and a modified VW golf disc setup on the rear, I ran a adjustable bias pedal box with mine. That setup works very very well, it stops on a dime. But thats probably a little exteme, maybe just the GT brakes up front and drums rear?
Wed Sep 22, 2010 5:49 pm
I have vented metro 4 pots up front and mini drums on the rear with an adjustable bias valve.
Stops very well!
Alex
(Gulf) GTM Coupe
Wed Sep 22, 2010 8:15 pm
I used 8.4" Mini solid discs with Metro 4 pot callipers and EBC Green stuff pads at the front and standard Mini drums at the rear.
I had a standard single circuit master cylinder and I didn't use a bias valve
Wed Sep 22, 2010 9:21 pm
7.5 discs on the front and std drums with 19mm bore brake cylinders on the rear. Assisted with a remote servo, it is working well soo far. Though I think I could do with slightly more power on the rear. Somebody menshioned using MGB brake cylinders on the rear? Maybe...
Thu Sep 23, 2010 6:38 am
Late MGB GT cylinders are the biggest I've found so far at 7/8" (22.2mm) part no GWC1122 approx £8 from MGPartsUK http://www.mgpartsuk.co.uk/prods/pc169.html
Thu Sep 23, 2010 11:58 pm
I've got Metro 4 pot fronts and Fiat X1-9 rears(disc), along with tandem/split master cylinder and hand brake cables. I've just bust the bleed nipple off the O/S/R :evil:, so I'll need to change the caliper to test them out (FIAT= Fix it again tomorrow). New stainless steel bleed nipples to be ordered.
Andy. Your bias adjuster I presume it reduces braking at the front? What's your % front?
I also have Fiat 132 rear calipers (larger diameter piston) but might be too much.
I'm also going to get this beast on the road soon!!!!
Fri Oct 08, 2010 3:14 pm
