big3ltr
Joined: Mon Jul 19, 2010 8:18 pm Posts: 20 Location: Bradford
 steering rack
Hi guys Ive juat started my build of my early coupe., I have taken the track rod ends off and there was only on about 4 turns on both sides. I dont no what the rack is off but i dont think they are on the thread enough. Any help please.
| Mon Nov 08, 2010 5:49 pm |
Alex Gibson (AXLE)
 Re: steering rack
You can get long track rod ends!
| Mon Nov 08, 2010 6:33 pm |
the other Tim
 Re: steering rack
I think Vizard said Spitfire ones are longer or you can get another pair of half nuts, screw them on the rack or a bolt with the track rod ends and carefully weld the nuts to the track rod ends (i'm pretty sure that was Vizards idea too  ) The former sounds much safer if you're in any doubt at all. Which ever way you go has got to be safer than your currant set-up. Negative camber bottom arms help to put the car in this situation.
| Mon Nov 08, 2010 6:53 pm |
big3ltr
 Re: steering rack
thanks guys. over the winter you will im sure be a great help to me. thanks
| Mon Nov 08, 2010 7:59 pm |
 Re: steering rack
Im sure there is a cooper s version that has a longer section that threaded and is ideal
| Mon Nov 08, 2010 8:27 pm |
Dino
 Re: steering rack
WEST wrote: Im sure there is a cooper s version that has a longer section that threaded and is ideal
Neil Not aware of one Neil. The Triumph ones are definitely available - cheaper than Mini ones at my local factor as well !
| Mon Nov 08, 2010 11:31 pm |
Ken555
 Re: steering rack
Truimph Spitfire mk1-4 - from 1962 to 1980 Part number GSJ158
Are what you are looking for, thats what I fitted. Just make sure to get Quinton Hazell ones, the "pattern" part one I had originally fitted, lasted less than a year / 3000 miles.
| Tue Nov 09, 2010 10:20 am |
Alex Gibson (AXLE)
 Re: steering rack
Ken555 wrote: Truimph Spitfire mk1-4 - from 1962 to 1980 Part number GSJ158
Are what you are looking for, thats what I fitted. Just make sure to get Quinton Hazell ones, the "pattern" part one I had originally fitted, lasted less than a year / 3000 miles. This is what i fit to all my minis, i never fit the short ones!! But as Ken said only fit QH, no cheap rubbish!
| Tue Nov 09, 2010 6:22 pm |
big3ltr
 Re: steering rack
Thanks for your time all.
| Thu Nov 11, 2010 4:16 pm |
