It is currently Mon Nov 23, 2026 6:07 pm
Ignition wiring help
Post Ignition wiring help
My MK2 Rossa doesn't want to start :(
I am having trouble with the coil end of the ignition system. I have in my engine bay the following:
1: a lead from the distributor
2: a female spade connector - white cable
3. a female spade connector - white with black tracer
4. a female spade connector - 2x white with black tracer
What goes on which terminal and what isnt used at all.
I am running points and the wiring loom is standard Rossa.
I want to rip it all out and make my own system with a MK2 metro fusebox and relays etc, but want to know what condition the engine is in before i start.
Any ideas/help welcome please.
Thank you.
Tue Mar 29, 2011 9:33 am
Post Re: Ignition wiring help
This is a generic ignition wiring diagram.
It may be some use to you.
Tue Mar 29, 2011 7:12 pm
Just to check - is it A series or A+?
If A plus threis a ignition module on the side of the dizzy and the wiring is slightly different.
Allen
Tue Mar 29, 2011 7:28 pm
Hi, cheers for the replies. the diagram helps me with which side of the coil needs connecting to what, but which of the above mentioned wires to i use?
It dosent have a module on the dizzy i dont think.
Wed Mar 30, 2011 10:10 am
According to the build manual, the purpose made loom follows metro colour coding - sadly I have a mini manual, not a metro - but a trawl of your local charity shops may help.
My instalation has been modified for an A+ engine, which has the module with two wires, one to each side of the coil.
Allen
Thu Mar 31, 2011 8:49 pm
i have both mini and metro manuals from various years, and none of them match the rossas'm wiring.
Cheers anyway.
Sat Apr 02, 2011 6:54 pm
there is a convention for looms
anything with a black tracer is a switched earth.
so your white wire should be power 12V, should be easy enough to check with a multimeter. The white with black trace would be earths such as from the points in the dizzy to the coil, and from the coil to the tacho.
Sun Apr 03, 2011 10:20 am
