It is currently Sat Nov 21, 2026 7:01 am
Gearbox bias spring
Post Gearbox bias spring
Does anybody have any experiance of the rod change bias spring kits for the A series.
They look like a good idea but will they fit? or are they just a gimmic
Paul
GTM coupe
Hawk Stratos in build
Sylva Star
Ex Larini/Ballista
Ex Mk1 Rossa
EX Mk2 Rossa x 2
Sat Apr 16, 2011 10:49 am
Post Re: Gearbox bias spring
Paul
If you have a look at this months Mini Mag (May) page114 Keith Carver is talking about fitting one to his racing car. They are also standard fit on Mini Spares 5 speed box's.
(Mini spares Part number MSG12)
Alex :wink:
(Gulf) GTM Coupe
Sat Apr 16, 2011 12:29 pm
Yes.
I have.
It worked well, helped a bit with that 3rd gear selection :wink: ,
Verdict.... ok for a road Coupe :D
Mon Apr 18, 2011 12:09 pm
The cheaper way is to fit a soft spring between the "U bend" of the gear linkage and the subframe.
Just pulls the gear lever over in neutral towards the 3/4 gate.
Mon Apr 18, 2011 3:50 pm
:wink: Oh yes 8)
Mon Apr 18, 2011 7:20 pm
Does it just bias to one side? ie 3rd and 4th
and where is it fitted
Paul
GTM coupe
Sylva Star
Ex Larini/Ballista
Ex Mk1 Rossa
EX Mk2 Rossa x 2
Mon Apr 18, 2011 7:49 pm
Paul
Yes bias it to 3rd and 4th only, so you have to "push" slightly to get to 1st & 2nd, just think like a modern car.
Fitted to the bottom of the gear change "u bend", at the front, using a jubilee clip, then to a p clip on the subframe, drivers side.
In my case there is a clip that holds the heater pipe and I used that.
Will try to get a picture soon.
If you want to experiment try it with a thick elastic band, or in my case a slice of inner tube and a couple of cable ties.
(Did I mention, I'm Scottish and therefore mean by default) :lol:
Mon Apr 18, 2011 8:57 pm
Ken555 wrote:
:lol: :lol: :lol: :lol: :lol: :lol:
(Gulf) GTM Coupe
Mon Apr 18, 2011 10:34 pm
