It is currently Sun Nov 22, 2026 5:30 pm
wiring led side repeaters
Post wiring led side repeaters
hello i have a pair of M3 door mirrors with repeaters in them. they are three wire. black is -iv. red goes to u2. blue goes to u1.
does anyone know what the red and blue need to be connected to? thanks for any help. :?
Sat Mar 12, 2011 10:31 am
Post Re: wiring led side repeaters
Blue - Connect to + Parking Light (could leave this probably)
Red - Connect to + Indicator
Black - Connect to Earth (Ground)
AFAIK
Sat Mar 12, 2011 11:22 am
Do you not also need a different flasher relay or resistors.
Sat Mar 12, 2011 12:02 pm
im not sure about a resistor as they are on a circuit board already in the mirror wth wires that i am told are ready to connect to 12v supply. i have a flasher for side repeaters as used on the mini and one for use without. thanks for your help i'll give it a go. i do have a spare set if it all goes pete tong
Sat Mar 12, 2011 2:27 pm
If you are wiring the LED repeaters in parallel with the normal indicator bulbs there should be no problem. Their current draw is so small that a normal flasher unit won't even know they are there.
This is actually what causes the problem if you replace normal filament bulbs with LED's. They don't use enough current to operate a standard flasher unit so you need to wire resistors in parallel with them to increase the current draw or use an electronic flasher unit which is independent of the current in the circuit.
Sat Mar 12, 2011 6:29 pm
Tim
is this what we were talking about, On the BBC's dash ECU warning light :?:
Smoke and tubes are not my forte as some of you know :roll: :oops:
Mon Mar 14, 2011 9:24 am
turbocox wrote:
Tim
No, more like the alternator problem in the coupe section. The lamp in the dash conducts in one direction, to excite the alternator but the opposite direction when it goes over voltage. You were using an led, which only conducts in one direction.
You need to add a lamp, to make it work correctly.
Give me a shout Stuart, if you need to sort it out still.
Tue Apr 19, 2011 9:53 pm
You can still use the LED if you wire a 100 ohm resistor in parallel with it to bypass enough current to excite the alternator.
The resistor needs to be at least 2w power handling. 5w would be better.
Wed Apr 20, 2011 8:22 pm
