It is currently Wed Apr 22, 2026 8:16 am
Rose Joints
Post Rose Joints
On my track coupe the steering tie arms on the back of the car are fitted with a mini? track rod ends at each of end the tie bar on both sides of the car.
I want to replace the inner track rod end on each side of the car with a rose joint that will fit on the tie rod thread.
Can anybody suggest a supplier of good quality rose joints that will fit the bill please?
Regards
David
Land Rover Freelander 2
BRA 289 Cobra replica
Porsche 968 Coupe
Radical PR6
Sat Jan 08, 2011 8:07 am
Post Re: Rose Joints
I got mine from Mcgill Motorsports but go for their premium quality ones rather than the cheapest ones.
Iain
Sat Jan 08, 2011 8:32 pm
fI also got my rose joints from Mcgill Motorsports. Iam very happy with the quality !
(Gulf) GTM Coupe
Sat Jan 08, 2011 10:17 pm
Good quality and go for seals or boots if you want them to last. (Rose joint is a trade name and they sometimes get sniffy if you refer to them generically.)
You'll need a left and right hand thread inserts http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330480862525&ssPageName=STRK:MEWAX:IT And tube to suit.
Thought about it myself, seeing the lefthand thread ordinary ball joint is hard to find and not cheap.
Sat Jan 08, 2011 11:50 pm
Thanks guys.
David
Porsche 968 Coupe
Radical PR6
Sun Jan 09, 2011 9:05 am
Does anybody know the thread size please?
David
Porsche 968 Coupe
Radical PR6
Sun Jan 09, 2011 9:14 am
1/2 UNF
I got some from rallydesign last and they have been long lasting, I have a mileage chart for replacing things such as these, Mcgill ones seem of good quality I have some but not ran them yet.
Sun Jan 09, 2011 11:18 am
I was rather hoping to get female threaded rose joints to screw on to the steering tie bars I already have - is this possible?
David
Porsche 968 Coupe
Radical PR6
Sun Jan 09, 2011 12:45 pm
David
Yes they exsist, As I Modified my car to run Rod ends on the inner pickups, LH thread 1/2 female are avaiable, they do tend to cost more than Males. Hence my new Suspension I have designed to use males as much as possible and moving towards a twin wishbone style setup 8)
Sun Jan 09, 2011 3:41 pm
Thanks Neil.
David
Porsche 968 Coupe
Radical PR6
Sun Jan 09, 2011 3:56 pm
McGill does the 1/2" lh female rod ends you're looking for, he also sells studded joints suitable for replacing the outer track rod ends, these will give you an easy way to do small amount of shimming to dial out bumpsteer.
Sun Jan 09, 2011 5:57 pm
I recommend Mcgill to those who buy the new top arm kit
from me. Unfortunately I cannot attach jpg to show.
The old track rods can be used with female rod ends
or Mcgill can supply connecting pieces to use male
ends.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Sun Jan 09, 2011 10:41 pm
I take it these are OK to replace the steering rack ball joints......
http://www.mcgillmotorsports.co.uk/index.php?act=viewProd&productId=159
Anybody know which ones I need to sort out the rear tie rods?
Fri May 13, 2011 9:44 pm
Yes they are good to replace the track rod ends.
Sat May 14, 2011 7:30 pm
