It is currently Sun Oct 25, 2026 2:20 pm
[ 6 posts ] |
Coupe177C
Joined: Sun Sep 19, 2010 2:28 pm Posts: 43 Location: Cardiff
 Packing Heat
I'm making slow but steady progress with my coupe. Not as easy as i thought but definately getting there!
As its technically a rebuild there is already a heater in there, not sure what its from, it doesnt look like a mini or metro that I've seen before. Its around the same size but has slider/switches on the side rather than in the middle.
There are a few dolomite bits like steering column and clocks (i thought it had a dolomite dash but i think i might be the lucky owner of a GTM one). Again though, I dont think its a dolomite heater.
So as far as aesthetics go, I would rather lose the heater and have a nice clear cockpit with a clean carpetted tunnel straight through but I know I will probably want a heater in the long run.
Has anyone has any success with electric heaters? Considered stashing one behind the dash with an on/off switch on the dash, but i'm aware theyre usually pretty Toffee due to the power available. Ive seen some micro heaters which may do the job but at around £100 its a bit steep.
So what does everyone else use (if anything)?
| Sat Jun 25, 2011 2:00 pm |
gtmdriver
 Re: Packing Heat
I used a Mini heater but hid it behind a centre console which reached from the bottom edge of the dash to the top of the transmission tunnel.
_________________ GRP rules!
| Sat Jun 25, 2011 6:22 pm |
ibrooks
 Re: Packing Heat
I'm planning to steal the idea from T7 design and just use a matrix and a couple of computer fans. I've got a bunch of fans from the back of some old comms kit we slung out at work and I was thinking of just using the Mini matrix since I know I'll be able to get a replacement in the future but if a different matrix is better/easier I'll use it.
Iain
| Sat Jun 25, 2011 7:19 pm |
CamelotR
 Re: Packing Heat
I "designed" my heater using a mini matrix and some easy-to-get bits. Take a look at it on my site if You wish (cr.fw.hu) . Funny, but it worked  .
| Sat Jun 25, 2011 9:40 pm |
Coupe177C
 Re: Packing Heat
Very nice work on your car Camelot. Very impressive!
| Sat Jun 25, 2011 11:48 pm |
CamelotR
 Re: Packing Heat
Thanks, but I am afraid, that pics are looking better than the reality  .
| Tue Jun 28, 2011 11:43 am |
[ 6 posts ] |
