It is currently Wed Apr 22, 2026 3:28 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
New Member
Post Re: New Member
Honda D16
Honda B16
Honda B18
Toyota 4age
Toyota 3s-gte
Vauxhall redtop
Vauxhall 1600 twin cam
A series
A series turbo
A series KAD 16V
K series
T series turbo
Alfa...? cant remember what one thow :roll:
Lancia Twin cam
Fri Jul 01, 2011 1:00 pm
Post Re: New Member
Yep Lancia sorry brain fade :roll: :lol:
Mr Mac wrote: I've been think about an engine swap as well - I did open discussions with MED on a sprint spec A series for next year but since we were heading north of £5.5k our conversations were concluded with a "if you need to ask you cant afford it" sort of comment..........shame as I like the a series. It's left me in a bit of dilemma now. I'd like to keep the car in line with it's build date so really want to go with a 1980's engine..........which is limiting!.
What about for an 80's car engine Imp :wink: :D
Rev's and lightweight
Fri Jul 01, 2011 7:45 pm
Post Re: New Member
80's???? :?
(Gulf) GTM Coupe
Fri Jul 01, 2011 8:01 pm
Post Re: New Member
80's????
Exactly! Didn't anybody make fast cars in the 80's?
Fri Jul 01, 2011 10:30 pm
Post Re: New Member
4A-GE '83 but don't go there. Honda D series goes back to 83/84.
Edit: Vaux 1.8 or Sri130 was a good engine, or Sierra Cosworth on an RS2000 box.
The Ford 1.6 CVH was a good engine if looked after.
Am I being sad?
Fri Jul 01, 2011 10:46 pm
Post Re: New Member
You don't need to spend £5.5k to build a decent A series. Have a chat with Carl at Force Racing; his cranks are probably the best without going billet/EN40B. MED will continue to charge ridiculous figures if people are willing to pay it.
It all depends on how much power you're after. I'm going to stick with the A series for now but every time I see photos of a VTEC in the back of a Coupe it makes me want to go that route...
Sat Jul 02, 2011 12:38 am
Post Re: New Member
I would like to put a 1.6 Vtec in my coupe, to replace the D series Honda that I currently have - who can make me a frame?
David
Land Rover Freelander 2
BRA 289 Cobra replica
Porsche 968 Coupe
Radical PR6
Sat Jul 02, 2011 7:17 am
Post Re: New Member
David
Can you use one of the standard kits produced for mini's? That way you will get the beefed up suspension etc to cope with the power. Suggest we talk as I might be interested in taking your existing setup of your hands.........
These guys might be able to mod their standard kit:
http://www.watsonsrally.co.uk/html/conversion_kits.html
David
Sat Jul 02, 2011 8:17 am
Post Re: New Member
My personal view is you can do better than a mini kit, alot of them are good but could be better, and when i looked many would not fit unless you changed wheelbase, hence why I am doing my own with proper a arm style suspension, still using mini uprights it is just time at the minute im struggling with using he car and work.
Sat Jul 02, 2011 10:06 am
Post Re: New Member
Mr Mac wrote:
David
David
I might talk to watsons - thanks for the link, but of course we are talking about putting one of their front subframes in the back of the GTM, a lot of modification would be required I suspect.
David
Porsche 968 Coupe
Radical PR6
Sat Jul 02, 2011 2:03 pm
Post Re: New Member
watsons when i looked, basically used a metro frame, so all new suspension as it is all different to mini, it is wider track and for a mini to the best of my knowledge requires an extended front.
Sat Jul 02, 2011 3:14 pm
Post Re: New Member
You are right, it does need an extended front for a standard mini. I have asked them if they have any experience working on a GTM.
David
Porsche 968 Coupe
Radical PR6
Sat Jul 02, 2011 5:11 pm
Post Re: New Member
It might be worth talking to Allspeed -- they do frames for GM/Honda/k series in mini -- the frames have a kink in the front cross bar, I think to clear the exhaust, which means they won't bolt up to the bulkhead but they might make one with a straight section and then lead the exhaust out over the top of the cross bar through the end of the tunnel> The Allspeed frame retains mini suspension with doughnuts or coil overs so the GTM system should fit.
Sat Jul 02, 2011 6:47 pm
Post Re: New Member
http://www.pistonheads.com/sales/largep ... model=CARS
If it goes in the front of a mini - how about the back of a coupe?
Sat Jul 02, 2011 8:27 pm
Post Re: New Member
Watsons have worked on a GTM Coupe before and will produce a space frame for the back, standard width which will take a B16 engine.
I am going to try to go to see them.
David
Porsche 968 Coupe
Radical PR6
Wed Jul 06, 2011 5:33 pm
