It is currently Fri Nov 20, 2026 10:32 pm
[ 5 posts ] |
John SS
 K3 Steering Rack
Can anybody tell me how to replace the steering rack on a K3, please? - do you have to drop the subframe?
| Tue Sep 06, 2011 5:53 pm |
PEEPS
 Re: K3 Steering Rack
Hi John, I am in the process of stripping the front off my K3 and looking at it I would think that if you disconnect the steering column at the bottom universal joint and then loosen the torque tube bolts at the subframe end, by then removing the bottom mount long bolts you should be able to tilt the subframe up at the front to give enough room to drop the rack out from the back having undone the 'U' bolts that hold it to the rear face of the subframe. Failing that you will have to remove the subframe. Peter.
| Tue Sep 06, 2011 7:32 pm |
John SS
Many thanks Peeps. J.
| Thu Sep 08, 2011 6:56 pm |
John SS
In fact, it involved dropping the whole subframe!
| Tue Sep 13, 2011 9:43 am |
PEEPS
Sorry John, mine did fight back a little but I am replacing it with a tubular subframe that will give double wishbones with coilovers to replace the hydragas. A long way off yet.
| Tue Sep 13, 2011 4:47 pm |
[ 5 posts ] |
