It is currently Sat Jun 13, 2026 10:18 pm
K3 advice
Post K3 advice
Hi i have a K3 completely striped & painted i also have an Mgf 1.8i complete to use as a Donner engine brakes etc will the mgf sub frames fit with out mods or should i use the metro ones, hydraulic clutch ?, Hand brake?, has anyone gone down this way before. Also what screen is used on the K3
Sat Oct 23, 2010 7:02 pm
Post Re: K3 advice
I believe the mgf subframe is identical to metro one but with as few additional brackets that may or may not need to be removed.I seem to remember the screen is from a citroen visa.
Sat Oct 23, 2010 8:34 pm
Post Re: K3 advice
post4132.html
Appears to agree about the screen
Sat Oct 23, 2010 8:37 pm
Post Re: K3 advice
The MGF sub frames are the same as a Metro but with extra brackets added, these can be removed and the subs will fit in place of the Metro units.
Sat Oct 23, 2010 11:22 pm
Post Re: K3 advice
As others have said the subs are ok to use, the only thing I would add is that if you use the MGF wheels as I have you will need to widen the wheel arches as they will stick out from the bodywork too far.
I would try to use the whole of the MGF running gear, cable gearchange, rear brakes and handbrake cables etc. as it is far superior to the Metro bits.
Sat Oct 23, 2010 11:44 pm
Post Re: K3 advice
I've had a new member contact me [as he's not got internet access] and I've managed to answer his questions but one, how close is the exhaust manifold to the fuel tank on the K3? His is within 50mm?
Bob S.
GTMOC Secretary
Wed Nov 23, 2011 10:17 am
Post Re: K3 advice
The fuel tank is inside the cockpit and the exhaust is in the engine bay, so there is fibre glass inbetween.
Wed Nov 23, 2011 6:29 pm
Post Re: K3 advice
O'er, thanks for your reply.
He tells me that a section has been cut out and the tank is exposed to the engine bay?
Bob S.
GTMOC Secretary
Wed Nov 23, 2011 7:28 pm
Post Re: K3 advice
Thats certainly not how it should be, i'm wondering if this has been done to allow the tank to sit far enough back. If he hasn't all ready the spot welded lip needs grinding back as far as possible and bending flush with the tank to allow it to sit far enough in.
I'm guessing somebody has tried to fit the tank without modifing it first.
Wed Nov 23, 2011 7:40 pm
Post Re: K3 advice
Would you [or any K3 owner] be willing to talk to him on the phone :?:
He seems a nice chap, based in Northern Ireland.
I'll understand if you don't want to get involved, once he got your number :roll:
Bob S.
GTMOC Secretary
Wed Nov 23, 2011 8:17 pm
Post Re: K3 advice
im also a new owner of a k3 in northern ireland (tandragee) , if he wants to get in contact or even have a look at mine its ok with me.
Thu Nov 24, 2011 1:36 am
Post Re: K3 advice
Hi cloghoge, many thanks for your offer.
Your not on the [paid up] members list so I don't have your contact details [other than your e-mail address], can you pm me your phone no and I'll pass it on to Jim Chalmers of Bangor.
Bob S.
GTMOC Secretary
Thu Nov 24, 2011 10:04 am
