It is currently Wed Apr 22, 2026 1:38 pm
Elise gearshift into Libra
Post Elise gearshift into Libra
Does anyone have any details/information on fitting the elise gearshift system into the Libra. I currently have a 1.8vvc/pg1 with rattle rods which gives me the slowest and vaguest gear change I've ever encountered and a sharp contrast to the MX5 gearchange I've been used to.
Regards BV.
Tue Feb 28, 2012 10:36 pm
Post Re: Elise gearshift into Libra
You can fit the MGF cable change without to much hassle.
Thanks Matty
Wed Feb 29, 2012 8:05 pm
Hi Matty,
I seem to remember you were looking at this. Did you do this and how well does it work. I've heard some reports its not much better? I need to do something as the russian roulette change is driving me nuts :x
Cheers BV
Thu Mar 01, 2012 11:17 pm
I fitted the mgf cables as I put PG1 gearbox in to replace a metro one although I never drove the car with the metro box and rod change.
MGF cables seem to work fine to me.Although I have just had to replace one as the cable snapped.
I am sure there are a couple of libras using elise gearchange but think there is a bit more work involved.
Matty
Fri Mar 02, 2012 7:52 pm
Hi Matty,
Did you use the MGF front part (gear lever end)?. Where did your cable snap? seems cables snapping on mgf's in not uncommon though I plan to get cables made the same place Roger did for his car as the place is quite close to me.
Cheers BV
Fri Mar 02, 2012 10:17 pm
Did not use the MGF front mounting bracket purchased the unit from GTM but after seen both I see no reason why the MGF one could not be cut down and modified to fit.
Cable broke right next to the rear end where it has the end crimped on.
Matty
Sat Mar 03, 2012 6:42 pm
What bracketry is needed for the gearbox end? Currently running the rod change.
SAS
Sun Mar 04, 2012 12:26 pm
From what I can remember just the brackets fited on the gearbox to hold the cables.
Matty
Sun Mar 04, 2012 8:21 pm
I think i may have the brackets you need. They were supplied as part of the Libra kit. I did not use them, because ia have a Honda engine and gearbox. So it was easier to make new brackets than modifiy the one supplied tp fit my gearbox. If the want brackets or more informationn please let me know.
Mon Mar 05, 2012 12:00 am
I have seen a build site for gtm spyder were they had replaced parts of mgf change with a kit from Mike Satur that replaces the plastic bushes that wear that cause play in the linkage but don't know how good or bad it was . I have done the lever end using modified mgf and gtm parts.
Mon Mar 05, 2012 12:15 am
