It is currently Sat Nov 21, 2026 7:02 am
Libra clutch change
Post Libra clutch change
Any tips or pitfalls to be aware of before I rip into this?
Wed Mar 28, 2012 1:30 pm
Post Re: Libra clutch change
Do not no if it is worth fitting one of these clutch release arms at the same time.
http://www.eliseparts.com/products/show ... lease-arm/
Not sure if the arm seizing is a problem but if one has been designed it must be.
Have made the assumption it is a PG1.
Matty
Wed Mar 28, 2012 8:26 pm
Hi Matty,
Yep I was planning to fit one of the Mike Satur lubricated type of release arm as I know they are a problem. My plan is to fit a replacement clutch as its done 50000m and swap out the relaease arm at the same time hopefully that will solve the slipping clutch.
Regards BV.
Thu Mar 29, 2012 10:57 am
Changed the clutch at the weekend and as I had suspected the operating lever was almost seized. Had to drill and tap the end and 'drift' it out with the slidehammer :shock:
Fitted the Mike Satur lubricated type lever and it works a dream.
Now I can finally give it the beans :mrgreen:
Tue May 01, 2012 1:03 pm
