It is currently Thu Jun 18, 2026 7:05 pm
windscreen rubber
Post windscreen rubber
Can any one tell me which is the best windscreen rubber to use thanks
Tue May 29, 2012 5:02 pm
Post Re: windscreen rubber
No time to find it at the minute but there is a thread on here somewhere re the windscreen rubbers. Search button at the top :wink: :)
Tue May 29, 2012 5:39 pm
i did have a look but couldnt find what i was looking for :oops:
Tue May 29, 2012 8:10 pm
There are a number of threads around but to answer the question:
I got mine from these guys; http://www.coh-baines.co.uk/
ref: IRS0767 w/s £2.23 per M when I bought it.
Tue May 29, 2012 8:20 pm
thanks dino did it fit ok
Tue May 29, 2012 8:27 pm
Or try these guys
http://www.sealsdirect.co.uk/shopping.a ... rtmentId=4
Iain
Wed May 30, 2012 11:14 am
hi iain do you know which one fits the coupe
Wed May 30, 2012 6:03 pm
Yes very much so, the only difficulty I had was that the screen opening was quite small so it was a tight fit, but that's not the rubber's fault.
Wed May 30, 2012 11:14 pm
You pick one the right size. They show the thickness of each side so you measure how thick the glass is and take an average of how thick the GRP is and get the suitable seal. Go for the low side of the GRP as its better for it to be tight than leak and you can always take a file to any really thick bits of the GRP (within reason).
Iain
Thu May 31, 2012 10:30 am
Thanks for that advise do you know if you can use the same type of rubber on the rear window :D
Thu May 31, 2012 6:20 pm
