flippspeed
Joined: Tue May 01, 2012 8:40 pm Posts: 190 Location: hampshire GTM: Cox/Coupe
 Re: r 1 coupe
yes it is nice to see it coming together just need me subframes top coated some time this week hopefully tomz then i can start to build
| Mon Oct 01, 2012 8:02 pm |
flippspeed
 Re: r 1 coupe
subframes top coated ready to come home hopefully tub ready for the weekend
| Tue Oct 02, 2012 7:42 pm |
flippspeed
 Re: r 1 coupe
top coated
| Tue Oct 02, 2012 7:58 pm |
flippspeed
 Re: r 1 coupe
bonnet ducted mould made and layed up waiting to be trimmed
| Thu Oct 11, 2012 7:54 pm |
flippspeed
 Re: r 1 coupe
front support brackets shot blasted and primed , front scoop needs laying up and blending in , subframes should be nearly complete by the end of  next week
| Sun Oct 14, 2012 9:07 pm |
flippspeed
 Re: r 1 coupe
scoop in progress
| Tue Oct 16, 2012 9:00 pm |
flippspeed
 Re: r 1 coupe
delivery from minispares today,bottom arms will be upgraded with high spec rose joints
| Sat Oct 20, 2012 1:02 pm |
flippspeed
 Re: r 1 coupe
tie bars are going to work to be upgrade with rose joints and make up some brackets,top arms all rebuilt ready for fitting today
| Sat Oct 20, 2012 1:05 pm |
turbocox
 Re: r 1 coupe
Aaaah..............I think I got it now Did you find the owner of the moulds I thought it wasn't going to surface for a while Is it back  , is it dermow's Cox In the back ground under the clear sheeting Why are the pictures of a Gtm coupe front end and not the Cox wide body you wanted Is the Cox owned by you now Or have you met up with the current Cox owner to use his moulds For those who don't know this car.... dermot-s-hillclimb-r1-coupe-t206.html?hilit=dermow
| Mon Oct 22, 2012 10:29 am |
flippspeed
 Re: r 1 coupe
hi turbocox the car under the sheeting is a fury not the wide body coupe,i wish it was as i would like a set of the moulds,iam going to extend my arches once i bring the tub home hopefully this  weekend
| Mon Oct 22, 2012 8:12 pm |
flippspeed
 Re: r 1 coupe
fvew things to add this week tub has had the sprayed on carpet fitted with some side plates
| Sat Oct 27, 2012 3:30 pm |
flippspeed
 Re: r 1 coupe
started on the subframes, been making few bits this week at work will post the pictures tomz
| Sat Oct 27, 2012 3:34 pm |
flippspeed
 Re: r 1 coupe
few more bits put on the subframes and few new bits,tie bars rose jointed got to repaint them as mark up in the lathe ,getting there slowy but ran out off bolts
| Sun Oct 28, 2012 9:09 pm |
flippspeed
 Re: r 1 coupe
The tub came home today the building will start tomorrow
| Sat Nov 03, 2012 6:27 pm |
flippspeed
 Re: r 1 coupe
nothing done this weekend but got myself a new clutch upgrade
| Sun Nov 04, 2012 7:12 pm |
