It is currently Tue Aug 18, 2026 2:54 am
Post new topic Reply to topic  [ 184 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 13  Next
r 1 coupe
Post Re: r 1 coupe
yes it is nice to see it coming together just need me subframes top coated some time this week hopefully tomz then i can start to build :D
Mon Oct 01, 2012 8:02 pm
Post Re: r 1 coupe
subframes top coated ready to come home hopefully tub ready for the weekend :D
Tue Oct 02, 2012 7:42 pm
Post Re: r 1 coupe
top coated
Tue Oct 02, 2012 7:58 pm
Post Re: r 1 coupe
bonnet ducted mould made and layed up waiting to be trimmed :D
Thu Oct 11, 2012 7:54 pm
Post Re: r 1 coupe
front support brackets shot blasted and primed , front scoop needs laying up and blending in , subframes should be nearly complete by the end of :D next week
Sun Oct 14, 2012 9:07 pm
Post Re: r 1 coupe
scoop in progress
Tue Oct 16, 2012 9:00 pm
Post Re: r 1 coupe
delivery from minispares today,bottom arms will be upgraded with high spec rose joints :D
Sat Oct 20, 2012 1:02 pm
Post Re: r 1 coupe
tie bars are going to work to be upgrade with rose joints and make up some brackets,top arms all rebuilt ready for fitting today
Sat Oct 20, 2012 1:05 pm
Post Re: r 1 coupe
Aaaah..............I think I got it now :idea:
Did you find the owner of the moulds :wink:
I thought it wasn't going to surface for a while :wink:
Is it back :?: , is it dermow's Cox In the back ground under the clear sheeting :shock:
Why are the pictures of a Gtm coupe front end and not the Cox wide body you wanted :?:
Is the Cox owned by you now :?:
Or have you met up with the current Cox owner to use his moulds :?:
For those who don't know this car....
dermot-s-hillclimb-r1-coupe-t206.html?hilit=dermow
Mon Oct 22, 2012 10:29 am
Post Re: r 1 coupe
hi turbocox the car under the sheeting is a fury not the wide body coupe,i wish it was as i would like a set of the moulds,iam going to extend my arches once i bring the tub home hopefully this :D weekend
Mon Oct 22, 2012 8:12 pm
Post Re: r 1 coupe
fvew things to add this week tub has had the sprayed on carpet fitted with some side plates
Sat Oct 27, 2012 3:30 pm
Post Re: r 1 coupe
started on the subframes, been making few bits this week at work will post the pictures tomz :D
Sat Oct 27, 2012 3:34 pm
Post Re: r 1 coupe
few more bits put on the subframes and few new bits,tie bars rose jointed got to repaint them as mark up in the lathe ,getting there slowy but ran out off bolts :(
Sun Oct 28, 2012 9:09 pm
Post Re: r 1 coupe
The tub came home today the building will start tomorrow :D
Sat Nov 03, 2012 6:27 pm
Post Re: r 1 coupe
nothing done this weekend but got myself a new clutch upgrade :D
Sun Nov 04, 2012 7:12 pm
