It is currently Tue Nov 24, 2026 10:23 am
wheel combo
Post wheel combo
hello guys would you mind taking a few moments to post what wheel size ( diameter and width ) and tyre size/make+model you are running and also what you think or if you would change. thanks in advance for the input. :D
Sun Sep 30, 2012 8:48 am
Post Re: wheel combo
bump
Fri Nov 09, 2012 9:57 pm
Sat Nov 17, 2012 8:27 am
Sorry I can't help you with this one - mine is sitting on the 13" pepperpots as supplied by GTM complete with a brand new set of 185's which are now unavailable but I can't comment apart from the tyre size because I haven't driven the damned thing yet :roll:
Sat Nov 17, 2012 8:50 pm
cheers for that, i seem to have the page missing with GTMs recommended sizes so i tried to see what tyer fitters views were but they couldnt say for certain what to put on.
Tue Nov 20, 2012 11:43 am
Are you after wheel offset or just tyre size?
Both my rossa's are using 185-60-13's, if you need the offset I could take a wheel off and measure it.
Paul
GTM coupe
Hawk Stratos in build
Sylva Star
Ex Larini/Ballista
Ex Mk1 Rossa
EX Mk2 Rossa x 2
Tue Nov 20, 2012 10:15 pm
Mainly rubber size. Hoping to just slap some paint on the wheels I have for now. 185 seems to be the norm so I will go for that size instead. Thanks guys
Tue Nov 20, 2012 10:20 pm
you will be fine with 155, 165, 175 or 185 !
ive run all those sizes on my 5 1/2 by 13 inch wheels
a narrow tyre has less rolling resistance than a wide one
(provided you inflate it properly)
the rossa was designed with 185s in mind and when I went with narrower
tyres steering got a LOT lighter at all speeds.
it is very clear in the build manual that you should use 185 / 60 x 13 inch tyres.
it does look sexier with 185s and I may be the only person with narrower ones fitted . . .
Mon Jan 21, 2013 7:48 pm
