Think you need to get the car on a flat surface and measure up underneath to find why you have such a big difference in suspension arm angles if you are using unmodified cones and struts.
The cone compressor bolt should pass through the chassis hole and screw into the cone and when tightened will allow the strut to be removed, good idea to tighten the bolt with the car on the ground, gravity helps
