It is currently Tue Apr 23, 2019 11:48 pm
Brake set up for coupe
Post Brake set up for coupe
I have some tarox 6 pots to fit to the front of the coupe. It currently has metro vented 4 pots on the front and solid minis on the rear. It's got a wilwood pedal box with adjustable bias. Should I put the 4 pots on the rear or just stick with the solid mini brakes for the rear? Thanks
Thu Jun 19, 2014 10:25 pm
Post Re: Brake set up for coupe
Haha that will tear your face off!!!! If you are intending to drive it harder than you already have been then i would swap rears as you may end up cooking them causeing back end to get loose! How is your hand brake connected?
Thu Jun 19, 2014 11:19 pm
The handbrake was the gtm handbrake calipers but I'm not going to use them them just a line lock in the front and maybe a hydraulic handbrake for the rear in future. Car will be running around 150bhp when done and used for various track/drag/sprint events (fun rather than competition...)
Fri Jun 20, 2014 7:59 am
