It is currently Thu Feb 21, 2019 11:51 pm
Identifying Front Hubs
Post Identifying Front Hubs
A daft question, but I'm trying to sort out various hubs etc lying around my garage and getting myself totally confused - am I correct in thinking that the grease nipples on the hubs fitted to the car should be facing forward? I'm getting my lh and rh hubs mixed up and now I'm wondering if I've put them on the correct sides :roll: Thanks.
Fri Jun 27, 2014 6:55 pm
Post Re: Identifying Front Hubs
brake caliper bolt holes to the front of the car. top grease nipple to the front, bottom to the rear aren't they?
Fri Jun 27, 2014 8:21 pm
Sorry, I should have said that It's drum type front hubs I'm asking about. They don't have calliper holes (obviously!) and both grease nipples are on the same side.
Fri Jun 27, 2014 10:18 pm
Can you find the casting numbers? As Im sure there is a different number cast into them for left and right and if you compare the number to say mini spares you may get a clue.
Sat Jun 28, 2014 7:27 pm
I've done that and neither Mini Spares or Mini Sport list it. I guess they have them remanufactured under their own number if they have them at all. However, the other one I have is an old MOWOG number and from looking on ebay I'm pretty sure that it's the left hand one so the other (2A4312-20) is the right hand. I already had the 2A etc one on ebay as the LH which was why it was bothering me and I have now edited the listing to say that it's the RH. Looking under the car wasn't much help because, as Midas says, the nipples are both front and back on the disc versions!
Sat Jun 28, 2014 10:16 pm
I have some drum uprights taken of my brothers mini when we put discs on, they are complete so will have a look at them later
Sun Jun 29, 2014 12:10 pm
Drum uprights
Grease nipples forward
Sun Jun 29, 2014 5:01 pm
I can confirm grease nipples face forward
Sun Jun 29, 2014 6:09 pm
Thanks chaps, much appreciated. I wouldn't like to sell an upright for the wrong side :roll:
Sun Jun 29, 2014 8:44 pm
I have 2 L-H upper arms if you need one :roll: :D
Mon Jun 30, 2014 6:59 am
No thanks, but at least you can identify yours :lol:
Mon Jun 30, 2014 10:43 am
