It is currently Mon Nov 23, 2026 10:06 pm
rossa heated screen
Post rossa heated screen
does anyone know if i can buy a rossa heated windscreen?
Mon Jun 06, 2011 9:43 pm
Post Re: rossa heated screen
I have no idea but it might help to know that the Rossa screens are actually from a Citroen Visa. I'm not sure about the K3 though.
Tue Jun 07, 2011 9:20 pm
One of the Midas forum members organised a group buy on heated windscreens from Ricky Evans Motorsport in Tamworth. Because the Fiat 127 screen used on the Midas cars is obsolete he had to supply a screen which was then shipped across to China to be used as a template.
From memory 20 screens set us back £250 per screen, a total bargain when you consider the improvements made to the driving experience in a car that was otherwise unusable in damp or frosty conditions.
Thu Aug 21, 2014 11:56 am
front glass / windshield in midas is from Fiat 126p. New item in Poland ( where fiat 126p was made ) cost about 150 PLN ( circa 30 GBP )
but not heated
Thu Aug 21, 2014 5:10 pm
Dagnabbit, one number out.....
I know they are a nightmare to get in the UK, the heated screen fixed the horrendous misting problems which are mainly due to the useless screen demister, something else I need to look at while the Midas is in bits.
Thu Aug 21, 2014 5:34 pm
You've probably looked already but Car Builder Solutions have a wide range of heating and demisting parts on their web site, some of which should be adaptable for your needs. Also, a slightly less neat but easier solution might be to use one of these heated electric fans that sit on top of the dash but you've probably seen these too :wink:
Thu Aug 21, 2014 8:37 pm
I tried the heated fans, sadly they are utterly useless, there's probably more mileage in using a heated blower from a production cabriolet, though they do tend to be quite long to be fitting under a dash. What I'm likely to fit are the in-line fans that fit into the corrugated tubing as it's the connection between the external fan and the rest of the car that's the problem on the Midas.
Thu Aug 21, 2014 9:06 pm
