It is currently Wed Jun 10, 2026 4:28 pm
Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
Post Re: Just bought 60s Cox GTM project NDB414G
Andy, I have some colour pictures of Howards race car :roll: :lol: ,
I will be going to the NEC aswell 8) so I will give you a call, we'll sort something out.
Mon Nov 03, 2014 9:22 pm
Some more progress this weekend. After a great day at the NEC on Friday I arrived home to a letter from the DVLA saying the logbook is on its way with the original reg number, great news as I now own a car not a lump of metal/plastic.
Spent Saturday with dad, a grinder and big hammer separating the tub from the top. We weren't sure how the two were joined together along the back sill sections as on other models we'd seen an open box section with access to bolts, the box section on mine was closed off. It turned out the top was riveted/stuck to a plate which was also riveted/stuck to the metal tub.
Now the top was out of the way we had better access to take snaps of the rear suspension and space to remove the gear linkage...
Next job is to get the welder out and sort those nasty holes....
Mon Nov 17, 2014 10:34 am
Making good progress!
Mon Nov 17, 2014 1:55 pm
Great stuff.
We love these project threads - especially with loads of pics. :D
Keep 'em coming... :D
Mon Nov 17, 2014 6:48 pm
A bit more progress on the GTM, the subframes are now stripped and ready to be sent off for powder coating along with all the suspension parts. You can see in the photo that the front suspension donuts have been slimmed down to soften them, as per the build sheet, also both suspension knuckles on the rear have snapped which I thought was odd, looks like they've been like that for a while. The front had single leading shoe brakes which along with the steel trumpets points to the donor car being quite early. As the rear brakes weren't connected it must have been frightening to drive!!
Drums might have helped the car stop if they had drums :)
My nephew Oliver building his own GTM...
Mon Jan 05, 2015 11:23 am
I'd love to buy these steel trumpets for my 1960 Morris Mini - I only have the rear ones. I have been lokking quite a while for then now, so please think about selling them.
dietmar
Wed Jan 07, 2015 3:22 pm
No problem, I will be using Hi-Low's.
Wed Jan 07, 2015 3:30 pm
It has been a long while what with a house move and various other projects on the go but here are some update photos.
The '1071' engine and gearbox have been rebuilt and stored away ready to fit. At the moment the tub is down with Chris and Tim at http://www.whights.co.uk having a few issues welded up and blasted.
Much needed strengthening added to the subframe mounts...
A coat of black to protect it while a few more welding bits are sorted...
Thu Sep 24, 2015 12:41 pm
Well done Andy,
A total rebuild seems to be a never ending job, but at least you had a complete car to start with :roll:
Look forward to more pics as you progress
Thu Sep 24, 2015 1:28 pm
After DropBox changed the access to my 'Public' folder all my old images now have broken links so here goes with another server. Below is the project...
This is the tub at the moment after a few weeks down at whights.co.uk
And here are some snaps from last week after a winter of buying, powder coating, machining, cleaning, rebuilding...
Front subframe with CVs machined flush...
Rear subframe using hubs from the front and rear backplates opened out to fit the hubs. The extended gear selector kit is from Rossabitz along with the steering arm locking kit...
Original welding on the pedals...
Rear setup on the left. Front cones on the right machined/drilled to try and soften the front suspension along with the top of the Hi-Low rounded off...
Finally got the engine built up after having the short motor done a year or two ago and the gearbox in January..
Wed Apr 19, 2017 8:59 am
A very traditional build and looking so nice.
jOHN
Wed Apr 19, 2017 11:21 am
Andy lovely workmanship mate
Ian
Wed Apr 19, 2017 12:46 pm
Looking good. I had read the profile of the top of the Hi-lo effects the spring rate. One day I will perform some tests, I am interested to see what the actual Wheel rates are
Wed Apr 19, 2017 1:11 pm
A bit more progress, subframes are on wheels ready for the tub and we're spraying the underside of the tub tonight, should have the whole tub done by early September...
Fri Aug 18, 2017 9:43 am
Looks great ☺
Sun Sep 03, 2017 7:50 am
