It is currently Sat Nov 21, 2026 11:09 pm
1.8 Turbo engine in K3
Post 1.8 Turbo engine in K3
Hi,
Just exploring options:
Has anyone looked at putting a 1.8 turbo engine in a GTM?
I ask because they seem to be cheaper and more plentiful than 160 VVC engines and by all accounts a flatter torque curve.
Also has anyone junked the Metro Subframes completely and built something to order?
Many thanks
Wed Aug 12, 2015 1:13 pm
Post Re: 1.8 Turbo engine in K3
Not sure about the turbo engine, there isn't much space available to the bulkhead, if the turbo is low down then maybe.
I dumped the front subframe so that I could have coilovers and double wishbone suspension on the front, see pic, and made some retro fitting brackets to fit the existing rear subframe converting that to coilovers. It is an MGF rear subframe, basically the same as metro so I will be using stock MGF rear end. I just wanted to lose the hydragas and have some adjustment.
Peter.
Thu Aug 13, 2015 11:40 am
Cheeky Peter
Good to see someone doing something a bit different with a K3, I am liking the front frame
Fri Aug 14, 2015 12:41 pm
Thats a nice piece of work, looks like a nice big garage too. :)
The owner isn't
Fri Aug 14, 2015 5:21 pm
You should see his nice home made 4 post lift all good stuff :wink:
Sat Aug 15, 2015 4:18 am
Hi PEEPS,
Do you have any idea of the weight of your new front subframe?
For that matter, does anyone know the weight of a MGF subframe?
Thu Aug 20, 2015 4:50 pm
Is it as good as this one:
Thu Aug 20, 2015 8:08 pm
:lol:
Thu Aug 20, 2015 9:09 pm
The MGF subframe weighs 29 kgs approximately and the tubular one weighs 23 kgs.
I just wanted adjustable wishbone suspension that would use the same mounting points.
Peter.
Thu Aug 20, 2015 9:49 pm
Peeps 4post is much easier to adjust :lol:
Fri Aug 21, 2015 4:15 am
The attachment Eds car lift.jpg is no longer available
This one's pretty easy too:
Apologies to Ed - I stole his pictures from the BKCC forum...
Fri Aug 21, 2015 7:35 am
I only use my forktruck on my mini, too many elf an safety issues! :wink:
Fri Aug 21, 2015 1:08 pm
