Re: New Coupe owner...finally!
So made a little progress today
I fitted the new water pump and the new oil pump no problems there.
Okay now I need some help as admittedly I am not totally sure I get the difference between pre-verto and Verto clutches but to me it appears I could have a half and half set-up with the clutch?
It has the pre-verto slave cylinder mounted to the top of the bell housing
and an inertia starter motor (this isn't my one but it's the same)
so I went ahead and ordered a pre-verto clutch kit. Now it looks like the innards are verto (again not my actual engine but it looks like this)
If I am misunderstanding something please let me know.
Assuming I do have a mixed bag can I use the clutch plate that came in the pre-verto kit? It looks exactly the same as the one I removed. Below is an image of the type that I removed and have re-fitted (it is not the type with springs in the plate)
As ever help is appreciated
