It is currently Wed Nov 11, 2026 3:19 pm
Started modelling
Post Started modelling
Hello all
No, I am not off to Milan fashion week...
Went over to get the rear suspension off my GTM on the weekend, and also did some measuring. most of it is quite easy to do but the front is a bit more tricky, mainly because the floor to front bulkhead junction is rusted away! may need some help with that bit, quite pleased with progress in Solidworks considering it is only 2 evenings work.
Mon Dec 07, 2015 11:53 pm
Post Re: Started modelling
Good 3D work there.
SAS
Tue Dec 08, 2015 11:51 am
sidewinder wrote:
Good 3D work there.
SAS
and sooo much easier and quicker than pencil on paper all those years ago when I was was in design office drawing front suspension and steering systems :wink:
Tue Dec 08, 2015 7:49 pm
Looks nice.
Did you measure it or did you get the dimensions somewhere?
How thick is the sheet?
Thu Dec 10, 2015 9:15 pm
Looks good,
Show me yours and I will show you mine :roll:
Mine is done In NX and sheet metal meaning I can unfold it for templates, Modelling all the joged edges and getting the split lines to work for drop down seat pans so that they are foldable has been bit fiddly
Thu Dec 10, 2015 10:32 pm
Nice model, I have got a fair bit done now. I got a bit stuck with where the floorpan meets the front bulkhead but TURBOCOX helped me out with some dims last night. Unfortunately mine has rusted away! should be able to do a lot over xmas hopefully.
Simon
Fri Dec 11, 2015 1:53 pm
Thought I would bring an update, finally had a bit more progress.
Ta Da
Getting my head around the triangular transition from bulkhead to tunnel caused a bit of thinking due to the tunnel walls not being vertical. Getting it to model in sheet metal was a bit of a pain but it unfolds on the computer now, need to add a couple more details and tidy the flange transitions a little.
The front wheel wells should be fun!
Mon Jan 25, 2016 10:45 pm
Progress!
I got some good drawings of the mini front subframe today so hopefully I can start on the front end soon, moving house on Friday though so no time for a while, will be drawing up my house instead...
Tue Jan 26, 2016 12:27 am
When I measured up my chassis to make my GRP replacement I found that very few side to side and diagonal measurements were the same so I found myself taking a lot of averages.
Tue Jan 26, 2016 8:46 am
