It is currently Mon Nov 16, 2026 8:18 pm
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
Shudders when enginebraking
I thought this wouldnt be de case because the car gets moves forwards and backwards often.
Will inflate them quite hard and store the car on blocks for a week, see if that will cure it.
Will make some big blocks to put under the jackingpoint at my work monday.
Harold
Sat Sep 03, 2016 12:32 pm
Harold
Alleycat style wheels are still available but they,re not made by the same company. Look on the Huddersfield mini spares website at the rally style wheel. I think they,re available in 6" and 7" widths.
Sun Sep 04, 2016 9:08 am
Thanks Steve, but I'm not searching for new Alleycat wheels, I was looking for someone who could tell me which wheelnuts should be used.
But after jacking it up and turning the wheels, I saw that the tires are not equal in hight, looks like they have flat spots from standing still.
Will lifting the car and inflating the tires to a high pressures cure the flat spots or is harm done and should I get new tires?
The width of the wheels normaly is placed in the inside of the wheel, but cannot find it on mine... :(
Harold
Mon Sep 05, 2016 7:09 am
Hi Harold,
I think Mini Spares do a selection of nuts for different wheels, You can try over inflating the tyres with the wheels off the ground, but it did not work for me :(
Mon Sep 05, 2016 7:17 am
John,
Already e-mailed them but didn't get an answer yet.
I'm afraid the wheelnuts are not the cause of the vibrations but the flat-spot-tires are.
So now I'm wondering what to do, overinflate the tires with wheels of the ground and hope this will help, or buy new tires 165/60/13 or new wider tires 175/50/13 (I would like to know the width and offset of my wheels now but cannot find them) or buy new wheels and tires, but don't now exactly what wheels with which offset will fit (with 165/60 or 175/50 tires) without rubbing.
Questions, questions....
Mon Sep 05, 2016 7:30 am
Measure your existing wheel offset, from the inside seating face where it sits on the hub flange to the inner edge of the rim. on my old cox I used to use 165x10 on the road and had a set of Pirelli P7 Corsa 175x13-50, fitted to 13x6 wheels, which were the lowest profile available back then to race with. I don't think 165x13 will be too narrow for road use and that is what I will probably use on the Kano Coupe, 50 series will be a more harsh ride.
Mon Sep 05, 2016 8:00 am
There are a set of Wolfrace wheels for sale over here, not new, need a bit of TLC, but I do like the looks of old Wolfrace slotted wheels. The seller sais they where meant for a mini, so they should fit, but he will measure up the pitch circle and offset.
He doesn't have wheelnuts or centrecaps.
They are 5,5 inch wide, will 165/60 or 175/50 tires fit these wheels? Or are they to narrow?
Has anybody got experencie with Wolfrace wheels and does anyone know if wheelnuts and centrecaps are still available?
Cheers Harold
Tue Sep 06, 2016 7:51 pm
I bought here in Kano a set of BBS 13x5.5 wheels here in Kano and plan to fit 165 tyres, a set of wheel came with my car and were fitted with 165 so should not be any problem, with my old Cox I started racing on 165 x 10 and only went about 1/2 second quicker per lap with 175 x 13 P7 Corsa.
Wed Sep 07, 2016 7:08 am
Harold,
If you go to the tyre manufacturers webs site there should be a chart that shows the wheel sizes recommended for the various tyre sizes.
I seem to remember that the range of possible wheel widths is quite large eg I think a 175 tyre can be fitted to wheels between 5.5" and 7" wide -- but please check before you buy anything!
Also -- where are you sourcing the 165x13 tyres? They used to be the Metro Turbo fitment but I haven't seen any for sale for some time -- the regularly available tyre appears to be 175x13 now.
Wed Sep 07, 2016 8:31 am
In our racing days we ran 185x60 on 13" wheels with no problem.
Wed Sep 07, 2016 12:44 pm
Sorry I meant 5.5" x 13 wheels
Thanks guys.
I thought I remembered some formula, take the width of the wheel, recalculate that to mm, and than go from 10 to 40 mm above that for tire. I don't know if I remember it well nor if it is accurate.
I havent really dug in to where to source the 165/60 tires. I have this size on my car now.
175/50 is an other option, but I must be certain that they will fit without rubbing.
But first see if I can cure the flat spots on my current tires.
Get it's wheels off the ground and overinflate them to 5 bar or something like that (if they can stand that kind of pressure)
@John: some time ago you gave me the tirepressure you use, I believe it was aprox 1,3bar in front, and 1,5 on the rear.
Isnt that a bit low? I believe classic mini's have a standard tirepressure of around 2bar.
Wed Sep 07, 2016 6:05 pm
Hi Harold,
Use Front 18 – 20 psi Rear 22 – 24psi as a starting point to find what is comfortable for you, remember Mini's have more weight on the front end than a GTM has on the rear, just as a reference I run 10 and 12psi on 8" and 10" tyres on my Jedi but it only weighs 300kg :D
Thu Sep 08, 2016 7:09 am
@John: That is about 1,3 and 1,6 Bar. (PSI is not a very common scale over here)
It's a lot less than the tirepressure on the classic mini which ways about the same.
On a Dutch mini-forum they say it should be about 2,1 Bar (30+ PSI)
The weightdistribution is a bit different, but still.
I will try some higher pressures, see how that goes.
But first try to make my tires round again... :lol:
Harold
Thu Sep 08, 2016 10:34 am
Try to grind away the high spot on the tyres with an angle grinder :lol:
That's the pressure range I used so long ago on my Cox, somebody is sure to reply if this is not correct :wink:
I just looked in my old Haynes Mini Manual here in my office and they quote Mini's as 1.9bar front 1.8bar rear
Thu Sep 08, 2016 10:43 am
