It is currently Mon Nov 16, 2026 8:06 pm
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
Shudders when enginebraking
Post Re: Shudders when enginebraking
The top arms run in needle roller bearings and if grease should have a long life but because the don't move very much up and down can wear a groove in the pins, if you can find any sign of movement forward and backward it's time to replace, rebuild kits are available but knocking the roller bearings out can be a but tricky.
Think Super Max got over excited last weekend and became "Mad Max"
Thu Sep 01, 2016 7:47 am
I will check them next weekend.
Max wanted a good result in front of his many Dutch fans, but screwed up his start. I liked his defensive actions :D
Thu Sep 01, 2016 8:10 am
I think Red Bull Liked his actions, Ferrari drivers not so much, lets see how he does next weekend
Thu Sep 01, 2016 8:21 am
Haha, again mainly Kimi and Max were fighting, don't think they will become best friends...
Next race is in Italy right? Don't think Max has many fans there... would be nice to finish in front of the Ferrari's :lol:
Thu Sep 01, 2016 8:48 am
If he keeps his cool he as has every chance :wink:
Thu Sep 01, 2016 8:50 am
Harold,
I could come up with some bullsh*t but I honestly don't know -- Ford overcame its wheel vibration problems -- an epidemic with Rostyles -- by spigoting the wheel to the hub. Every one does that now -- eg see metro hubs.
Fri Sep 02, 2016 8:38 am
Hi Steve, I would guess spigots to centralise the wheels better to reduce run-out/vibration?? that was my thought for raising the car and rolling the wheels to see any run-out
Fri Sep 02, 2016 8:59 am
I have thought about my fitted old Alleycat wheels too.
Because the old nuts were bad I bought new ones (with radius) without really knowing what kind of nuts the wheels would require.
Maybe other nuts would centralise the wheel better? I thought wheelnuts with radius centralise best?!
Must find someone who knows which nuts I need (No not that ones).
Somehow this seems more likely to me to cause the vibrations/Judders than the lower-arm-issues
Harold
Fri Sep 02, 2016 10:04 am
And having improved the bushing situation the problem is now at a higher speed, which make me to think the bushings and joints are not the problem.
Fri Sep 02, 2016 10:12 am
Does "Alleycat" still produce wheels?
Can't find a manufacturer sofar.
If I want new 13" wheels in the future, what sizes am I limited too? 6x13 with 165/60 tires? and what offset? Won't 175/50 tires fit? Too wide?
Harold
Fri Sep 02, 2016 10:54 am
I used to run 175-50 on 13"x6" when racing on my old Cox that was made for 10" wheels, so should be no problem on later cars made for 13' wheels.
Fri Sep 02, 2016 11:02 am
Thanks John,
Do you have an idea what offset I shoould have?
Or will all 6x13" wheels that are advertised on mini-parts-websites fit?
Harold
Fri Sep 02, 2016 11:08 am
Hi Harold, Its too long ago (early 1980's)for me to remember the offset, I did have to use extended arches to keep the race scrutineers happy, the revolution wheels I used were intended for Mini's if that helps.
Fri Sep 02, 2016 11:45 am
I just jacked my car up, and when I turn the wheels I see quite a bit of tire-hight-difference on all 4 wheels.
Maybe I should inflate the tires to a too high pressure (2,5 bar?), Jack it up and put blocks under the car so the wheels don't touch the ground when I don't drive it, see if that helps.
Harold
Sat Sep 03, 2016 10:48 am
Ho Harold,
That is what I had been thinking was the problem, I had flat spots on the tyres of my race car from where it was stored in the trailer, it almost shook the teeth out of my fillings :wink: now I store the car with wood blocks under the corners of the chassis.
Sat Sep 03, 2016 11:13 am
