It is currently Wed Nov 18, 2026 3:09 am
[ 6 posts ] |
Rear Shock Absorber Mounting
Lakeland997
Our project GTM is progressing slowly (my son will update his thread soon) but I wonder if we could pose a question. The project car we bought has separate shock absorber brackets fitted at the rear while the new chassis has welded on brackets. Which type would you guys recommend? The separate ones look stronger to us (although the previous owner has fitted the shock absorbers upside down!). If we used those however, we would look to add a tubular spacer where the bolt goes through.
File comment: New chassis
File comment: Project car
| Mon Jan 09, 2017 4:37 pm |
grizzler73
 Re: Rear Shock Absorber Mounting
Never seen separate brackets before! If you use the fixed style a good modification is to gusset the bracket to the chassis leg that runs back to the bulkhead. There is a topic about it somewhere, West has done it to his car I think. Simon
| Mon Jan 09, 2017 8:45 pm |
grizzler73
Just to clarify, the way your new chassis is done is the correct GTM design.
| Mon Jan 09, 2017 8:47 pm |
Starmag
The separate ones looks like they are only fixed in place using one bolt?
| Mon Jan 09, 2017 9:48 pm |
Lakeland997
You can't see in that image but those separate brackets have a horizontal part that sits between the subframe and chassis in place of the spacer at the top of the subframe. I'll get a picture of a whole bracket tomorrow and post it. I thought they were a standard GTM part and you guys would recognise them.
They look a very strong design (except that they need a spacer tube for the bolt) so I'm tempted to cut off the factory brackets and use them.
| Mon Jan 09, 2017 10:53 pm |
Lakeland997
Just found this picture on another post and it answers my question. They are for the Rossa!
| Tue Jan 10, 2017 11:50 pm |
[ 6 posts ] |
