It is currently Thu Mar 21, 2019 1:47 pm
Design Axle Weights
Post Design Axle Weights
Help please. For IVA I need design axle weights for 1969 Cox GTM. Original specification detail does not include this information, only gross weight.
Thu Mar 14, 2019 9:10 am
Post Re: Design Axle Weights
Welcome Paul, 8)
As the axles are still In the same place as they are in the mini subframe, are they not the same as they would be for the mini :?:
My Cox last weigh in was 620kg it’s lost abit since then, but still over 600kg’s.
I don’t have a Cox brochure in front of me but from memory it states something like 10,hundred weight which is equating out at 509kg :shock: seems ambitious ?
But still this equates to a weight comparable to a 60’s mini.
Fri Mar 15, 2019 10:36 am
Thanks for your reply, Agree that the gross weight in the original brochure looks a tad light at 10.5 cwt, will be putting on weigh bridge to check actual weights.
Sun Mar 17, 2019 12:28 pm
Hi there,
When my old car was road going I took it over the weighbridge at work and it weighed exactly 660 Kg.
I also did some messing around with bathroom scales to try and get some corner weights to enable me to calculate the spring rate required for the rear coil overs that I fitted.
Unfortunately the notes went when I sold the car, but from memory the front to rear split was about 60:40.
What else have you done for the I.V.A?
Regards
Derek Hambly
Tue Mar 19, 2019 7:34 pm
Going from memory my fully laden Coupe with me
in it weighed 800kg. 340kg front & 460kg rear.
I was on a service call to a company and there was
a weigh bridge next door.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Wed Mar 20, 2019 10:27 am
