It is currently Fri Apr 17, 2026 3:57 pm
Post new topic Reply to topic  [ 335 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23  Next
Paul's k3
Post Re: Paul's k3
I vote for going straight to cover, but take your time doing it!
Tue Mar 26, 2019 10:29 pm
Post Re: Paul's k3
I have gone for the covered look
Thu Mar 28, 2019 4:36 pm
Post Re: Paul's k3
I'm waiting for some better weather so I can paint my wheel arches in time for the kitcar show at stoneleigh
Image Image
In the meantime, I made a center console
Image Image
And yes that is a mousetrap in my car
Fri Apr 05, 2019 7:07 am
Post Re: Paul's k3
I have got some paint on the car
Image Image
I would say it looks good but :oops:
I don't think using a paint brush worked :? :roll:
Image Image
it also shows how bad my paint has faded the top part of the wheel arch is a lot lighter my car needs a full respray
Sat Apr 20, 2019 8:13 pm
Post Re: Paul's k3
I'm back looking at the speedo calibrator I have a speedo working on the bench so I can play with the input
Image Image Image
Fri Jun 07, 2019 4:30 pm
Post Re: Paul's k3
Its been so wet this summer i have had time make my Speedo bored all I have to do is write the programme for it
One that works :o
Tue Jun 25, 2019 9:25 pm
Post Re: Paul's k3
ooo a little Nano. :D
Its great what you can get these days, I have a mega that I have had a little play with for different little projects very basic but been very helpful.
Sun Jun 30, 2019 11:39 am
Post Re: Paul's k3
It is amazing what you can get I think I might have killed the nano so I got this oscilloscope kit to test the arduino
Mon Jul 01, 2019 4:33 pm
Post Re: Paul's k3
I have a new toy for the k3 um right how am I going to get this to fit. I think the new center console might have to be changed :shock:
the speedo will have to wait
Image Image
I could move the radio up but I have a big hole for the clock I don't know if it will fit in between the bottom of the dashboard and the clock or I could cut the bottom of the dashboard and fit top in the dashboard and the bottom it into the new center console but I do not know if the dash is part of the k3,s strength
Sat Sep 07, 2019 5:07 pm
Post Re: Paul's k3
I started to fit a car stereo but look what happened
I thought I would sort out some wire's then end up fitting a DBO2 plug for the ecu
Image Image Image Image
Fri Sep 27, 2019 8:00 pm
Post Re: Paul's k3
Where did you get you little PCB made for the speedo calibrator?
Sat Sep 28, 2019 9:17 am
Post Re: Paul's k3
hi I used aisler https://aisler.net/ to manufacture the pcb there are overs on the net
i also used http://fritzing.org/home/ to design the bored then sent to aisler to manufacturer the pcb bord I used this as it worked well with arduino
you can use any
https://www.autodesk.co.uk/products/eagle/
http://www.kicad-pcb.org
it can be a bit of a pain to do
Sat Sep 28, 2019 8:55 pm
Post Re: Paul's k3
Awesome..
starting to gather parts for my arduino project at the mo a protoboard will suffice but maybe one day I will need my own little pcb
Sun Sep 29, 2019 9:18 am
Post Re: Paul's k3
I just mist a parcel that was deliverd :roll:
But when i whent to pick it up :?:
Look what it was
Very nice
I no what I want for Xmas (am I allowed to say it yet ) a set of Adjustable Coil overs
big thanks to peter for the parcel
Tue Oct 15, 2019 3:11 pm
Post Re: Paul's k3
I was just going to fit a car stereo and I end up buying all this :?:
I'm going to fit a second battery
Tue Dec 03, 2019 2:24 pm
