It is currently Sat Nov 21, 2026 6:35 am
A+ Engine and Gearbox Nuts,Bolts and Screws
Post A+ Engine and Gearbox Nuts,Bolts and Screws
Anyone have a list of all the nuts, bolts and screws used to screw together everything on the engine and gearbox?
There used to be a list on Minifinity, but since there website went belly up, they don't seem to have it anymore.
I was going to use the original screws etc, but I've made such a good job of cleaning up the rest of the engine it would be a shame to not have new screws to go with the shiny paintwork!!
Wed Aug 27, 2008 9:32 pm
Post Re: A+ Engine and Gearbox Nuts,Bolts and Screws
Joey on Turbominis came to the rescue with this one, so I'll post it on here, so I don't loose it again!
Timing Cover
5 x Bolts Cap Head 5/16"UNF (3/4" Long)
6 x Bolts Cap Head 1/4"UNF (7/16" Long)
5 x Washers 5/16"PLN (5/8" OD)
5 x Washers 5/16"SPR (1/2" OD)
6 x Washers 1/4"PLN (9/16" OD)
6 x Washers 1/4"SPR (7/16" OD)
1 x Nut 5/16"UNF (1/2" Head)
1 x Nut 1/4"UNF (7/16" Head)
Coolant Circui
2 x Bolts Heater Tap 1/4" UNF (7/16" Head, 1/2" Long)
2 x Washers Heater Tap 1/4" SPR (3/8" OD)
2 x Bolts Radiator Top 1/4" UNF (7/16" Head, 1 1/2" Long)
2 x Washers Radiator Top 1/4"PLN (9/16" OD)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 2" Long)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 1" Long)
4 x Washers (Water Pump) 5/16"PLN (5/8" OD)
4 x Washers (Water Pump) 5/16"SPR (1/2" OD)
Thermostat (Short)
3 x Bolts 5/16 UNC (1/2" Head, 1 1/2" Long)
3 x Washers 5/16" SPR (1/2" OD)
Engine Electrical
2 x Bolts (Alt' top) 5/16"UNF (1/2" Head, 2" Long)
1 x Bolt (Alt' Bottom) M8x20
1 x Nut (Alt' Bottom) M8 NyLoc
4 x Washers (Alternator) 5/16"PLN (5/8" OD)
4 x Washers (Alternator) 5/16"SPR (1/2" OD)
2 x Nuts (Alternator) 5/16"UNF (1/2" Head)
2 x Bolts Starter Motor 3/8"UNC (9/16" Head, 1 1/4" Long)
2 x Washers Starter motor 3/8"SPR (5/16" OD)
1 x Bolt (A+ Distributor) 5/16" UNF (1/2" Head, 3/4" Long)
Clutch Slave (Non verto)
2 x Bolts (Cyl Mount) 3/8"UNC (9/16" Head, 1" Long)
2 x Washers (Cyl Mount) 3/8"SPR (5/8" OD)
1 x Bolt (Arm Stop) 1/4"UNF (7/16" Head, 1" Long)
1 x Lock Nut (Arm Stop) 1/4"UNF (7/16" Head)
Clutch Cover
8 x Bolts 5/16"UNC (1/2" Head, 1" Long)
8 x Washers 5/16"SPR (1/2" OD)
8 x Washers 5/16"PLN (5/8" OD)
Tappet Chest
2 x Bolts 5/16" UNF (1/2" Head, 1 1/4" long)
2 x Washers 5/16 PLN (5/8" OD)
Pre A+ Distributor Drive
1x Bolt 1/4"UNF (7/16" Head, 3/4" long)
1x Washer 1/4"SPR (3/8" OD)
Fuel Pump 2 x Bolt 5/16" UNC (1/2 Head , 1 1/2"long)
2 x Washers 5/16" SPR (1/2" OD)
2 x Washers 5/16" PLN (5/8" OD)
Oil Filter Housing
2 x Bolt 3/8" UNC (9/16" Head, 1" Long)
2 x Washers 3/8" SPR
2 x Washers 3/8"PLN (15/16" OD)
Manifold Bolts
6 x Bolt 5/16 UNF (1" Long)
6 x Washers 5/16" SPR (1/2" OD)
6 x Washers 5/16" PLN (5/8" OD)
(i would double check them first though)
Thu Aug 28, 2008 6:52 am
Alternator bottom nut is 3/8 UNF
I think it's pretty sad that I spotted that......
Thu Aug 28, 2008 8:41 am
