It is currently Fri Apr 26, 2024 4:12 am
Gaz Shocks damping control
Post Gaz Shocks damping control
Can anyone tell me which way the damper knob increases/decreases damping? Mine are either set to maximum or minimum damping, not sure which..
Thanks.
Sat Apr 25, 2020 2:29 pm
Post Re: Gaz Shocks damping control
Rightie tightie, leftie loosie. :)
Sat Apr 25, 2020 2:49 pm
Seriously, for road use on GAZ I'd back it off all the way left and then go right 6 clicks on the front and 8-10 clicks on the rear, for track use I simply add 2 clicks both ends. Any more than that I find it too firm. Have a play and see what works for you.
Sat Apr 25, 2020 2:51 pm
Presuming westfield left the same shockers etc on the Spyder, I always set ride heights at 140mm front and 155mm at rear.
Running on 17'' rims with the 205/40 Toyo tyres the shockers were set on 9/10 clicks (about half) on rear and usually a couple less on the front.
Hope that helps
it gave me a comfy ride around the Borders
Phil
Forgot to mention I always found tyre pressure made a great difference and seem to remember 23 front 24 rear
It worked for me :D
Sat Apr 25, 2020 6:26 pm
Thanks for the info. The damping was all wound up to max, I’ve backed it off to midway and will start from there.
Sat Apr 25, 2020 7:54 pm
