Blowning fuse & indicators u/s
Post Blowning fuse & indicators u/s
:oops: My cunning plan to swap the stalk switches - every time I want to overtake or turn I put on the wipesr :mrgreen: ) actually worked.
However, I did not replace everything before testing - and the choke cable shorted on one of the ingnition switch terminals. Indicators initially worked one side but not tother, replaced blown 35 amp fuse and indicator relay, fuse blew again and indicators do not work - hazards work with ignition off.
I assume I've melted some wiring and thus have a short?
Thu Apr 02, 2009 9:39 pm
Post Re: Blowning fuse & indicators u/s
Allen7 wrote:
...I assume I've melted some wiring and thus have a short?
Yes, well probably :roll:
The question is, what?
The ignition switch generally has three or four wires to it (assuming it's basically Lucas wiring.)
Permanent live in
Switched live out
possibly a separate ign. feed
feed to starter motor relay
If you earthed the live in, you'd have a dead short from the battery through the (normally either white/red or brown) permanent live, to earth - I'd expect the live wire to heat up and burn through.
If it was the switched live you earthed: either a/ nothing would happen if the ign was off or b/ again a short from battery - through permanent live - through switch (to switched output) - to earth.
If you earth the starter feed - nothing happens unless you were operating the key at the same time! If so then as above.
None of these senarios 'should' effect the indicator circuits, unless of course it was shorted for long enough for the affected wire to burn through adjacent wiring - that's quite a long time and lots of smoke.
So my initial opinion, you've either done something else as well! or you didn't just short the ign. switch !!
You'll probably have to check through the wiring carefully looking for the burn. - Start by tracing the live feed in.
Thu Apr 02, 2009 11:35 pm
If a Mini loom has been used i think there may be a seperate flasher unit for the hazards on some years. I seem to remember my son's did, that was a mid 80's car. If thats the case then look for some inline fuses elsewhere. It may be worth a gander at some Mini wiring diagrams
Thu Apr 02, 2009 11:48 pm
Likely: Duff hazard switch if you are using the std mini one, they are notorious for packing up.
Just as likely: wrong flasher
Almost just as likely, mucky contacts in indicators.
Or melted wires - time to get the multimeter out
I've been thru all of this myself last year, so if you need any more specific help, shout up.
Fri Apr 03, 2009 8:39 am
What you need is a refill kit for the Lucas smoke in the wires :lol:
Fri Apr 03, 2009 9:37 am
D'oh, I was going to post that.....
http://www.mez.co.uk/lucas.html
Fri Apr 03, 2009 9:48 am
Pew :roll:
All sorted now - after checking much of the loom behind the dash I revisited my super duper modifcation, only to discover that one of the indicator wire terrminals was touching the metal mount for the plastic shroud - the shorting choke cable was nothing to do with it, just got me barking up the wrong tree.
Should anyone else be fed up putting the wipers on at every overtake I can tell you how to swap stalk switches - and how not to :mrgreen:
Fri Apr 03, 2009 8:38 pm
