Re: Blowning fuse & indicators u/s
Allen7 wrote:
...I assume I've melted some wiring and thus have a short?
Yes, well probably
The question is, what?
The ignition switch generally has three or four wires to it (assuming it's basically Lucas wiring.)
Permanent live in
Switched live out
possibly a separate ign. feed
feed to starter motor relay
If you earthed the live in, you'd have a dead short from the battery through the (normally either white/red or brown) permanent live, to earth - I'd expect the live wire to heat up and burn through.
If it was the switched live you earthed: either a/ nothing would happen if the ign was off or b/ again a short from battery - through permanent live - through switch (to switched output) - to earth.
If you earth the starter feed - nothing happens unless you were operating the key at the same time! If so then as above.
None of these senarios 'should' effect the indicator circuits, unless of course it was shorted for long enough for the affected wire to burn through adjacent wiring - that's quite a long time and lots of smoke.
So my initial opinion, you've either done something else as well! or you didn't just short the ign. switch !!
You'll probably have to check through the wiring carefully looking for the burn. - Start by tracing the live feed in.
