Has anyone ever heard or seen a supercharged 1430 motor??? I was thinking of possibly supercharging my setup just for a bit more poke. If you can supercharge a 1380 then there should be no probs supercharging a 1430 as its only a stroked version. Any advise would be welcomed.
Fri May 01, 2009 11:00 pm
roger
Re: Supercharging
I'm sure I read somewhere that engines with a longer stroke respond better to supercharging than shorter stroke engines.
No real help I know
Fri May 01, 2009 11:15 pm
thunderossa
Re: Supercharging
Back in the day (1975ish) I ran a 1275 with a shorock supercharger. The main problem was the compression. I had to run the dished 1300 pistons If I put the flat tops in the engine detonated and destroyed itself. Technology has moved on allot but 1430's don’t come cheap so I would get some serious advice
