It is currently Wed Aug 26, 2026 8:44 pm
Supercharging
Post Supercharging
Has anyone ever heard or seen a supercharged 1430 motor??? I was thinking of possibly supercharging my setup just for a bit more poke. If you can supercharge a 1380 then there should be no probs supercharging a 1430 as its only a stroked version. Any advise would be welcomed.
Fri May 01, 2009 11:00 pm
Post Re: Supercharging
I'm sure I read somewhere that engines with a longer stroke respond better to supercharging than shorter stroke engines.
No real help I know :oops:
Fri May 01, 2009 11:15 pm
Back in the day (1975ish) I ran a 1275 with a shorock supercharger.
The main problem was the compression.
I had to run the dished 1300 pistons
If I put the flat tops in the engine detonated and destroyed itself.
Technology has moved on allot but 1430's don’t come cheap so I would get some serious advice
Sat May 02, 2009 6:10 am
