It is currently Fri Nov 13, 2026 5:21 am
engine probs
Post engine probs
hi there,my engine is a A+ 1275 metro,the carb looks like a HIF 44 ? but its got six pipes on the side one is the fuel inlet,one the crankcase vent and one the vacumm pipe to the dissy what are the other three may be they are why the engine will not start.thanks for your time
Thu May 21, 2009 9:03 pm
Post Re: engine probs
One will be the float chamber vent.
A photo might help.
Thu May 21, 2009 9:30 pm
Hi thanks for reply
attatched is picture of the carb. The green tabs indicate pipes that im unsure of
the webber carb on the picture do yoy know what maintainance the sponge filter needs does it need to be soaked in oil or left clean and oil free
Sat May 23, 2009 11:01 am
This is what I think they are.
I'm not sure about the bottom one.
The best thing to do with that filter is to replace it with a properly designed one from K&N, Pipercross, ITG, Green or similar. The old Speedograph units don't flow and they don't really filter either.
Sat May 23, 2009 2:31 pm
hi ,i forgot to say the vacuum pipe is on the top under the rag sorry about that and thanks for your time
Sat May 23, 2009 6:02 pm
Thats a Turbo HIF carb.
1 to fuel regulator top connection (Pressure sense)
2 Part throttle lean off, joined to 3
3 Part throttle lean off
4 Anti-run on valve
5 Fuel in
6 - Vac take off to Distributor
Sat May 23, 2009 9:13 pm
hi there thanks for your reply have i got the right carb for the car its a 1275cc a+ and could you tell me where these ports on the carb connect to?the 1 3 4 5 ports are about 5mm number 2 is about 10mm and i have got it connected from the carb to the 2 oil separators.number 6 is connected to the dizzy thanks for your time
Sat May 23, 2009 10:15 pm
Damn! I wasn't even close!
Sun May 24, 2009 8:34 am
You might have to swap the needle to match the engine.
But as far as hoses go, I would join 2 & 3 with a short hose.
Then block off 1 & 4.
Sun May 24, 2009 10:38 am
Thats a soo-called "economic" carb. Not realy power-friendly...
I had problems with one of its kind with getting good CO results.
Sun May 24, 2009 6:34 pm
