It is currently Wed May 06, 2026 8:49 pm
Coupe frame weight
Post Coupe frame weight
Hi Guys,
Does someone actually knows what the bare frame of a coupe weighs?
cheers.
Sun Sep 20, 2009 9:59 pm
Post Re: Coupe frame weight
My 83 coupe tub completly bare including paint came to 83kg on the dot bar a few grams. Not much!
http://mintecminispares.com/
Mon Sep 21, 2009 8:51 am
Thank you,83 kilos not bad me thinks.cheers.
Mon Sep 21, 2009 9:43 am
I remember 78Kg's somewhere from the depths of my memory :mrgreen: But I haven't had one on the scales so I'd suggest 80Kg's is a fair average, It maybe the 78Kg figure is the Cox weight
Mon Sep 21, 2009 10:13 am
From memory I weighed one roughly and 90Kg comes to mind, ill see if I have a note somewhere this was a late 80s tub and i think it had a couple of small bits of sound insulation on. So around 85-90kg seems about right.
West.
Mon Sep 21, 2009 10:35 am
'67 Cox GTM original frame was 72kgs (inc. moss and mushroom, but excluding missing floor, sills etc) , my tinkered frame is now 85kgs (the sweat and tears built in ads a bit...).
Mon Sep 21, 2009 11:41 am
Perhaps they beefed up the later tubs to cope with the more 'ample' frames of the post-Cox Coupe drivers?? :D :D :shock: :wink:
Regards,
Pete.
MGF Mk2 VVC
Merc Axor (company 'car').
Mon Sep 21, 2009 11:47 am
CamelotR
What gauge panels did you use and is it stainless?,cheers.
Mon Sep 21, 2009 6:29 pm
Hi,
The panels range from 1mm-2mms thick. The sills, the tunnel and the "towers" and the crossmembers are stronger than the rest. And it is not stainless.
At the beginning of the work I was tempted to do the frame of aluminium a'la the Heerey Cox, but I realized I am not skilled enough to do this.
Maybe You are thinking of something like this?
Tue Sep 22, 2009 5:50 am
Yea thats right,just planning at this stage,dreaming of a next gen coupe,a little bit bigger,much stiffer stronger,without touching the bodywork,maybe with a diesel engine,cheers.
Tue Sep 22, 2009 1:58 pm
Put a full rollcage in it, and it will add the rigidity You are looking for or even more.
Making the sill, tunel etc tougher is adding only limited amout to overal chassis strenght in my opinon.
Diesel engine??? My Dear God!... Blaspheny... errr... maybe a v6 TDI... not that bad...
Tue Sep 22, 2009 7:57 pm
Are you going to fit a tow bar too? :wink: :shock: :) :)
Seriously though, I toyed with the idea myself (diesel engine!) as modern common-rail jobbies are quite pokey, but I couldn't find anything that weighed less than half a ton, which would no doubt give a Coupe that Porsche 911 feel...
The only manufacturer that I could find that does a relatively lightweight alloy diesel engine is Japanese (Nissan :?: ).. though it's 2.2ltrs and would undoubtedly cost a packet as it's brand new..
Regards,
Pete.
MGF Mk2 VVC
Wed Sep 23, 2009 10:26 am
The other consideration is gearing, as most cars these days have rather large wheels/tyre combos compared to the coupe, I have had some thoughts on how do attack this myself
Wed Sep 23, 2009 10:37 am
How about a Citroen AX / Saxo or Metro 1.5 Diesel. Must be dirt cheap by now.
Would give you a range of 500 + miles, just take you a few days to get there :lol:
Griff
Wed Sep 23, 2009 9:43 pm
No not one of the horrible old engines,a common rail one has to be the way to go,isn't the ford peugoet 1.6 tdci all alloy 16valves?
Thu Sep 24, 2009 12:03 pm
