It is currently Tue Jun 09, 2026 9:35 am
Front bodywork mounting - the one under the fuel tank
Post Front bodywork mounting - the one under the fuel tank
I'd read somewhere that if the bonnet doesn't line up well with the tub the front mounting needs packing - it seemed to me that the fit was getting progressively worse, so I drained the tank and removed it. The origional builder had packed it using a pile of small diameter washers, these had broken through the fiberglass - the bolt probably wouldn't have kept on going through the bottom of the tank but still glad I checked it out.
Allen
Wed Mar 03, 2010 11:33 pm
Post Re: Front bodywork mounting - the one under the fuel tank
Mine was packed the same way when I got it and I cut a piece of flat bar instead which will spread the load better.
Thu Mar 04, 2010 12:30 pm
Job done and it gave me a chance to renew the rubber fuel hose from tank to pump - it was quite perished.
Also told me that the pump pumps the tank almost dry and the fuel guage (acewell) starts flashing when there's almost two gallons left.
Allen
Thu Mar 04, 2010 10:32 pm
