I think all you need to do is to replace the rubber bump stop to make sure the top arm doesn't droop. It says it in the Haynes manual I think. Otherwise you won't be able to take the ball joint apart when you split it. Might just need a shim taking out to take out the play. Might be worth a little investigation before making up a shopping list of parts needed. You will save time getting a decent ball joint splitter, not one with a fork that you smack with a hammer!!
Good luck
