It is currently Wed Oct 28, 2026 2:00 pm
radiator
Post radiator
hi what type radiator is the best suited for the coupe any one know :D
Mon Jul 23, 2012 4:24 pm
Post Re: radiator
It was originally designed around an Austin Allegro 1750 radiator but nowadays any of the modern aluminium/plastic radiators are fine. Just choose one which fits in the space correctly. I used a Metro twin pass version.
Mon Jul 23, 2012 8:01 pm
Post Re: radiator
have you got any pictures of its fitment plz
Mon Jul 23, 2012 8:10 pm
Post Re: radiator
Vauxhall combi van TDI version :wink:
Mon Jul 23, 2012 9:23 pm
Post Re: radiator
hi neil have you any pictures of how you mounted it please :D
Tue Jul 24, 2012 8:31 am
Post Re: radiator
hi any one got any pictures of how to mount the radiator thanks
Wed Jul 25, 2012 9:05 pm
Post Re: radiator
If you use an Allegro radiator it has 4 "pegs" (2 top, 2 bottom) on the surround -- the two bottom pegs fit into brackets bolted to the front face of the hinge bracket -- holes should already be there -- and the top two are held by long straps that bolt to the top face of the hinge bracket. The radiator sits at around 60 deg. I'll try to take some pics later but if you root around on the site for some front end build pics they should show the assembly.
Thu Jul 26, 2012 12:17 pm
Post Re: radiator
thanks steve that would be very helpfull as i have no brackets or fixings, so i can make some from the pictures cheers
Thu Jul 26, 2012 6:05 pm
Post Re: radiator
If you haven't already done so search for 'radiator' in the Projects forum - there's some stuff in there that might interest you :wink:
Thu Jul 26, 2012 10:39 pm
Post Re: radiator
thanks i will give that a go :D
Fri Jul 27, 2012 6:55 am
Post Re: radiator
Hopefully attached 3 pics of the radiator mounting in my somewhat wear worn Coupe -- an Allegro 1500 radiator I think -- top strap, view from underneath showing lower bracket and general view from the side showing installation angle more like 75 deg than 60 --hope this helps.
Messgae to self -- You really should get on and sort this car out.
Fri Jul 27, 2012 6:24 pm
Post Re: radiator
Thanks very much for that steve should be able to get some thing sorted now :D
Fri Jul 27, 2012 9:02 pm
