It is currently Wed Nov 11, 2026 11:32 pm
Rear A arms
Post Rear A arms
Does anyone know what the bushes were from on the rear A arm suspension set up for the Coupe?
Are they from a production car, or a GTM special?
Thu May 08, 2008 11:05 am
Post Re: Rear A arms
The inner bushes are standard Mini bottom arm bushes.
I could not find out what the outer bushes were from.
In the end I made my own from polyurethane rod supplied by Superflex with stainless steel pivot bushes.
http://www.superflex.co.uk/sprods.php
I think the 1" diameter stuff is OK in 80 Shore hardness.
If you're really stuck I could machine some for you if you know the dimensions you need.
Thu May 08, 2008 11:30 am
hi the outter bushes are orignaly from a MG try a mg specalist like the the mg beehive or similar good luck and dont forget to use high tensile bolts preferably 10.9 or higher to help prevent those nasty bolts shearing off on their threads
Sun Aug 24, 2008 8:11 am
