Spot the carb (and try to fix it...)
Hi all.
Its that time of year again. I've been strong and spent out the £5 on battery clamps that ive been putting off for months and started playing with the coupe again.
Its been about 6months since its started and although it turned over well, it wouldnt start. It hasnt started since i changed my jerry can fuel solution to a proper tank so i reverted to the can again, same problem.
If i splash fuel into the carb it will start for a few secs so ignition is fine. If i take of the fuel pipe at the carb and turn it over i am getting splashes of fuel (mechanical pump) so fuel is getting up there. So i took the top of the carb off, removed the piston and needle and gave that a gentle clean as it looked a bit corroded, back together and oil in dashpot and it almost started the first time, almost wasnt enough though and its doing the same thing now, only starts when force fed.
Would be great if anyone has any thoughts on what could be the problem. Is it worth opening up the float? When i took off the fuel pipe it seemed like there was a little bit of pressure there and the fuel *popped* out. There is also a pipe that goes nowhere (see pic) not sure if that is right but its always been the same and has started before. If i blow down the pipe i get fuel in the carb (not sure if that was a good idea or not). Should that just be out in the air?
Finally, im not even sure of the type of carb it is.... HIF44?
Thanks in advance
