It is currently Sun Nov 08, 2026 10:49 am
Yoda74
 Re: Suspension Coupé
I just did some measurements and took a look at the lower front arms. The arms are welded and have reinforcements. If I measure hart to hart of the weldings, I measure aprox 13 mm, that's about 1/2". The rubbers/ bushes of the lower arms and tierods had their best time. The tierods are both a bit bend, not very straight.
I measured the groundclearance from the sill down. In the front it was aprox 105mm, that is 4 1/8" In the back there is more space, about 130mm, that is 5 1/8" A bit low, it looks nice, but the bottom already hit a few speedbumps, even when going very slow.
What is the best way to go? The back has HiLo's, so I can raise the back. The front is a different story, go with some new rubbers, bushes and rubber cones and see where we stand then, or buy HiLo's, and the minispares mssk3013 kit? I have to get a good allignment in an allignmentworkshop then.
Does anybody know if I can order at minispares from Holland? It seems a lot cheaper then when I get the same goods over here.
Harold
| Fri Oct 30, 2015 10:41 am |
