It is currently Sat Nov 07, 2026 7:52 am
upper arms
Post upper arms
As I only had 2 L-H upper arms and they are like hens teeth here I have fabricated 2 upper arms with plan to fit coilover shocks, the AVO shocks are still in the UK as I had too much to carry on my last return. As I have not found a L-H rack I may re-engineer a R-H rack which I have, by turning the pinion around and passing it through the shim plate cover and blanking off the seal hole. this would entail the use of a universal joint in the column as the rack would be pointing in towards the car center line :roll:
Sat Jun 21, 2014 6:38 pm
Post Re: upper arms
I know its a bit late but I should have a top arm come available in a few months time when I replace my rear frame.
Sat Jun 21, 2014 8:57 pm
Post Re: upper arms
Hi Neil,
Would you like a weekend in Kano :lol: and can you bring a 4 shocks and a screen with your luggage??
Sun Jun 22, 2014 4:38 am
