It is currently Sat Nov 21, 2026 6:46 am
[ 3 posts ] |
A+ Engine and Gearbox Nuts,Bolts and Screws
Tim Rowe (1130)
Anyone have a list of all the nuts, bolts and screws used to screw together everything on the engine and gearbox?
There used to be a list on Minifinity, but since there website went belly up, they don't seem to have it anymore.
I was going to use the original screws etc, but I've made such a good job of cleaning up the rest of the engine it would be a shame to not have new screws to go with the shiny paintwork!!
_________________ Tim Rowe
| Wed Aug 27, 2008 9:32 pm |
Tim Rowe (1130)
 Re: A+ Engine and Gearbox Nuts,Bolts and Screws
Joey on Turbominis came to the rescue with this one, so I'll post it on here, so I don't loose it again!
Timing Cover 5 x Bolts Cap Head 5/16"UNF (3/4" Long) 6 x Bolts Cap Head 1/4"UNF (7/16" Long) 5 x Washers 5/16"PLN (5/8" OD) 5 x Washers 5/16"SPR (1/2" OD) 6 x Washers 1/4"PLN (9/16" OD) 6 x Washers 1/4"SPR (7/16" OD) 1 x Nut 5/16"UNF (1/2" Head) 1 x Nut 1/4"UNF (7/16" Head)
Coolant Circui 2 x Bolts Heater Tap 1/4" UNF (7/16" Head, 1/2" Long) 2 x Washers Heater Tap 1/4" SPR (3/8" OD) 2 x Bolts Radiator Top 1/4" UNF (7/16" Head, 1 1/2" Long) 2 x Washers Radiator Top 1/4"PLN (9/16" OD) 2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 2" Long) 2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 1" Long) 4 x Washers (Water Pump) 5/16"PLN (5/8" OD) 4 x Washers (Water Pump) 5/16"SPR (1/2" OD)
Thermostat (Short) 3 x Bolts 5/16 UNC (1/2" Head, 1 1/2" Long) 3 x Washers 5/16" SPR (1/2" OD)
Engine Electrical 2 x Bolts (Alt' top) 5/16"UNF (1/2" Head, 2" Long) 1 x Bolt (Alt' Bottom) M8x20 1 x Nut (Alt' Bottom) M8 NyLoc 4 x Washers (Alternator) 5/16"PLN (5/8" OD) 4 x Washers (Alternator) 5/16"SPR (1/2" OD) 2 x Nuts (Alternator) 5/16"UNF (1/2" Head) 2 x Bolts Starter Motor 3/8"UNC (9/16" Head, 1 1/4" Long) 2 x Washers Starter motor 3/8"SPR (5/16" OD) 1 x Bolt (A+ Distributor) 5/16" UNF (1/2" Head, 3/4" Long)
Clutch Slave (Non verto) 2 x Bolts (Cyl Mount) 3/8"UNC (9/16" Head, 1" Long) 2 x Washers (Cyl Mount) 3/8"SPR (5/8" OD) 1 x Bolt (Arm Stop) 1/4"UNF (7/16" Head, 1" Long) 1 x Lock Nut (Arm Stop) 1/4"UNF (7/16" Head)
Clutch Cover 8 x Bolts 5/16"UNC (1/2" Head, 1" Long) 8 x Washers 5/16"SPR (1/2" OD) 8 x Washers 5/16"PLN (5/8" OD)
Tappet Chest 2 x Bolts 5/16" UNF (1/2" Head, 1 1/4" long) 2 x Washers 5/16 PLN (5/8" OD)
Pre A+ Distributor Drive 1x Bolt 1/4"UNF (7/16" Head, 3/4" long) 1x Washer 1/4"SPR (3/8" OD)
Fuel Pump 2 x Bolt 5/16" UNC (1/2 Head , 1 1/2"long) 2 x Washers 5/16" SPR (1/2" OD) 2 x Washers 5/16" PLN (5/8" OD)
Oil Filter Housing 2 x Bolt 3/8" UNC (9/16" Head, 1" Long) 2 x Washers 3/8" SPR 2 x Washers 3/8"PLN (15/16" OD)
Manifold Bolts 6 x Bolt 5/16 UNF (1" Long) 6 x Washers 5/16" SPR (1/2" OD) 6 x Washers 5/16" PLN (5/8" OD)
(i would double check them first though)
| Thu Aug 28, 2008 6:52 am |
Pantera2075
Alternator bottom nut is 3/8 UNF
I think it's pretty sad that I spotted that......
| Thu Aug 28, 2008 8:41 am |
[ 3 posts ] |
