It is currently Fri Nov 06, 2026 1:02 am
steering rack
Post steering rack
Hi guys
Ive juat started my build of my early coupe., I have taken the track rod ends off and there was only on about 4 turns on both sides. I dont no what the rack is off but i dont think they are on the thread enough. Any help please.
Mon Nov 08, 2010 5:49 pm
Post Re: steering rack
You can get long track rod ends!
(Gulf) GTM Coupe
Mon Nov 08, 2010 6:33 pm
I think Vizard said Spitfire ones are longer or you can get another pair of half nuts, screw them on the rack or a bolt with the track rod ends and carefully weld the nuts to the track rod ends (i'm pretty sure that was Vizards idea too :!: ) The former sounds much safer if you're in any doubt at all.
Which ever way you go has got to be safer than your currant set-up. Negative camber bottom arms help to put the car in this situation.
Mon Nov 08, 2010 6:53 pm
thanks guys. over the winter you will im sure be a great help to me.
thanks
Mon Nov 08, 2010 7:59 pm
Im sure there is a cooper s version that has a longer section that threaded and is ideal
Mon Nov 08, 2010 8:27 pm
Not aware of one Neil.
The Triumph ones are definitely available - cheaper than Mini ones at my local factor as well !
Mon Nov 08, 2010 11:31 pm
Truimph Spitfire mk1-4 - from 1962 to 1980
Part number GSJ158
Are what you are looking for, thats what I fitted.
Just make sure to get Quinton Hazell ones, the "pattern" part one I had originally fitted, lasted less than a year / 3000 miles.
Tue Nov 09, 2010 10:20 am
Part number GSJ158
This is what i fit to all my minis, i never fit the short ones!!
But as Ken said only fit QH, no cheap rubbish! :wink:
(Gulf) GTM Coupe
Tue Nov 09, 2010 6:22 pm
Thanks for your time all.
Thu Nov 11, 2010 4:16 pm
