It is currently Wed Nov 11, 2026 11:22 pm
[ 3 posts ] |
Andy
 Caster Angle
Has anyone found a good caster angle for the Coupe?
| Thu Jun 19, 2008 8:49 pm |
gtmdriver
 Re: Caster Angle
I was running with 3.5 degrees caster and it was fairly stable but I also had about 4mm of total toe in at the rear.
When I had 3mm of rear toe in it was a bit quirky and I was thinking of increasing the caster angle to stabilise it and give it a little more self centering.
_________________ GRP rules!
| Fri Jun 20, 2008 8:49 am |
 Re: Caster Angle
Run 5.5- 6 degrees myself depending what camber im running, generally run 3mm total toe front and anywhere between parallel and 3mm to in on the rear, generally the 3mm total toe in on the rear seems to tame my power better.
| Fri Jun 20, 2008 9:01 am |
[ 3 posts ] |
