It is currently Sun Apr 19, 2026 12:42 am
Caster Angle
Post Caster Angle
Has anyone found a good caster angle for the Coupe?
Thu Jun 19, 2008 8:49 pm
Post Re: Caster Angle
I was running with 3.5 degrees caster and it was fairly stable but I also had about 4mm of total toe in at the rear.
When I had 3mm of rear toe in it was a bit quirky and I was thinking of increasing the caster angle to stabilise it and give it a little more self centering.
Fri Jun 20, 2008 8:49 am
Run 5.5- 6 degrees myself depending what camber im running, generally run 3mm total toe front and anywhere between parallel and 3mm to in on the rear, generally the 3mm total toe in on the rear seems to tame my power better.
Fri Jun 20, 2008 9:01 am
